Electrically dead Boomer?
/ Electrically dead Boomer? #1
Ssequels
New Jersey
Boomer 40, Deer 2210, Ford 8N
I just purchased a Boomer 40 a few weeks ago and so far it was a good tractor. I was cleaning some things near my tractor and the instrument panel ended up getting hosed over. Probably should have been move careful, but didn't think a bit of water would hurt things. Afterwards, the keyswitch would not engage the starter, but it would make some of the dash lights flash. I decided to let it sit overnight in case it needed to dry. Since then nothing. I still have 12.9 volts on the battery, but no electrical activity. I checked small fusebox under the left panel and those are fine. The manual shows a 50amp maxifuse somewhere near the starter and have not located that one yet. There are quite a few relays under the dash. Is there a way of testing them? I'm pretty handy with my old Ford 8N, but this one has me confused.
/ Electrically dead Boomer? #2
Welcome
I would start by taking both battery cables off and wire brushing both sides of cables and attachment points, then reconnect & try again
/ Electrically dead Boomer? #3
A blown fuse would be a cheap fix but I don't think that's it. It is possible you still have moisture somewhere that's not evaporated. If your tractor is run by a computer this could be worse than you imagine. Most tractors can take sitting out in the rain but I have no idea what direction your water spray could have come from or the amount of force behind it. Figuring that out will go a long way toward deciding where the water got in. Water and electricity don't mix well.
/ Electrically dead Boomer? #4
Do you have an operator's manual? They often have wiring diagrams in them. Otherwise see if you can find a shop manual or may be someone who has a wiring diagram will post it for you.
2017 Ford F-350 Crew Cab Service Truck with Liftgate (A64556)
2017 Ford F-350...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
More info coming soon. (A64553)
More info coming...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
UNUSED FUTURE HYD AUGER SET (A65055)
UNUSED FUTURE HYD...
2011 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65053)
2011 GENIE Z-45/25...
