Electrical System Help
/ Electrical System Help #22
Hi Joe
Are you SURE you don't have a fuel shut off? My CK30 HST has a pull knob just under the key that will kill the fuel flow.
Al
/ Electrical System Help #23
For you VT, I just went out and looked. No shut off. I have a black plug just below and towards the center of the key and another plug just above and to the center that I believe is for a horn. Maybe they decided not to use it anymore?
While inspecting the fuel pump in the past I have noted a cable rigging without the cable and I would likely try that and a few other things before blocking the intake. Unless I am experiencing a diesel runaway and then I will do whatever I can to kill it.
/ Electrical System Help #24
Can you explain what diesel runaway is ?
Thanks ...
John
/ Electrical System Help #25
Diesel runaway is when the engine finds a source of fuel other than diesel from the pump. The fuel source is unregulated and will allow the engine to rev past redline and potentially be destroyed. The usual fuel source is engine oil from rings, or valves. I've never had it happen to me but if it does I will shove whatever I have into the intake to kill the air supply or stand back and watch the show.
There are two types I know of. One where the engine experiences an increase in RPM's and You can't shut it down with the ignition or throttle or other normal means....The other is when the same thing happens only it's in gear and you're either on or off the machine...
/forums/images/graemlins/shocked.gif
Praying of course that the The rpm's are on the LOW side.... /forums/images/graemlins/crazy.gif
/ Electrical System Help #27
Everyone is giving good advice....
Remember tho a bad POSITIVE can do really wierd stuff too.
Check them both and check for acid in the battery. The start circuit on these tractors is very simple. Good positive, good ground, good switch....they will at least turn over, typically. Starters usually last very well, along with the glow plug circuit too.
KO
/ Electrical System Help #28
Mine is a 2004 model and has the same knob as VT explained. If you saw one and its hook up, you could probably add it pretty easily unless they removed the control linkage parts at the engine. I've never used mine yet. Always have used the key.
/ Electrical System Help #29
NO manual shut off? That's strange. I also have this knob on my CK30HST. Maybe one of the dealers can add something here?? Never used mine........yet.
/ Electrical System Help #30
All of the CK 25 and 30's on my lot.....
The HST all have a manual engine stop cable
All the gears do not have a manual stop.
I am not sure of this reason.
/ Electrical System Help #31
Rick has the answer to the missing engine stop.
HST has it and gears don't. I guess Kioti believes that you can always stall the engine with the clutch. For the few dollars more, Kioti should put the engine stop on all of them and instead of pulling the knob, pushing it in would be faster in an emergency.
/ Electrical System Help #32
Well mine is an HST without the shutoff. My old dozer was shutoff that way every time since key pretty much only ran the starter and the gauges.
/ Electrical System Help #33
Rick, don't all the LB1914s turn off with the fuel stop? That's a gear model. I'm surprised they don't all have them.
John
/ Electrical System Help #34
I think it is a running change alot of times. When we first started all of the LK's had compression release knobs on the dash. Now they don't...or maybe they do. You never know. Same with seats, Roll bars, remotes, mid PTO's, tire brands and I'm sure other things I've missed. Oh yeah electronic front wheel engagement.
KO
/ Electrical System Help #35
You would think that Kioti would keep some things standard. A fuel shut off should be standard equipment in my opinion.
I was hoping that Rick had the answer. It would make better sense than just not installing them for a while. /forums/images/graemlins/confused.gif
2018 Ford Explorer AWD SUV. (A66738)
2018 Ford Explorer...
CAT D6 SU Blade / Arms (A68134)
CAT D6 SU Blade /...
2010 BRENNER TANK PUP TRAILER (A67714)
2010 BRENNER TANK...
1999 Johnson 25hp Boat Motor 225hp 2-stroke Boat Moter (A66738)
1999 Johnson 25hp...
2015 CATERPILLAR 525D DUAL ARCH GRAPPLE SKIDDER (A65056)
2015 CATERPILLAR...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
