tcartwri said:
It's my understanding that is what he is doing. He's moving the small solar array from the cottage up to the existing array on the main house. Then running a feeder line back down to the cottage.
That would be correct.
A bit of history: the cottage was built during a series of 2 week visits from shortly after buying the property in 2003 until we moved there in 2005. When we moved in 2005, I built a small solar system. I found a diagram in HomePower magazine, bought panels and some parts via eBay. Worked quite well - as a learning tool. It started with only the 4 sharp 123w panels. My wife lived there while I returned to Ga to finish getting our house to put on the market. Unfortunately, she choose to listen to the neighbors and didn't run the generator nearly enough for the batteries. We nursed about 6 months out of them. We also learned about conservation. I added the 125w panels to improve, changed the charge controller to an Outback MX60, and took much better care of the new batteries. Also replaced the generator with a Honda EU3000i. We lived there until fall of 2007 when our new house was habitable. We sized the house solar with the thought to eventually connect. Last year, I remodeled the cottage, adding a roof to the lanai. Unfortunately, that roof blocks 2-3 hours of morning sun. In April my Honda went on the fritz and estimated 7-800 to repair. So after seriously considering where to relocate my panels, factor in that my batteries are now 6 years old, the loss of my Eu3000i, just seemed time to bite the bullet and consolidate. Yes, it will cost a bit more initially and be more work and take longer, but the long term benefits win out. The panels become part of the main system, I can upgrade my extra charge controller and swap out and have a spare, only one battery bank to maintain, and sell off my freed up inverter and even recover a bit on the extra batteries etc. My main house system was professionally done although I have changed out and improved a couple of minor components this past year. There is also existing room in my combiner box for the 3 new strings of panels. The 4 Outback FX3048 inverters were installed to accommodate the expansion.
I did buy my wire today. 500 ft spools of #2 copper, $749 at HD, minus my military discount. I did briefly consider using larger gauge Alum, but decided to go with the copper, as did my electrician when he ran my other sub panels.
John47 - have you evaluated your wind? My first attempt at expanding my small system was to add an AirX - big mistake for me. I did it based on how windy it was at night and winter. Even though I could see the little light glowing and the needle bounce a bit, I never saw my batteries plus send up in the morning. I often wished I had bought 2 more panels at the time. The L-16s have a mixed reputation around here, then again so do most of the installers. Based on what you have posted, I'd be tempted to suggest just installing a set of golf cart bats and after you have all your generation worked out then install a good set.
