Electrical Relay Question
/ Electrical Relay Question
Excellent suggestions for me to look for.
This relay and wiring is all from a kit so wire gauge and loads should be ok.
The lights do not work at all this time so different failure mode too. After reading all this I am excited to dig into troubleshooting. Yes, I am odd to be excited about something like that. :D Stay tuned...
/ Electrical Relay Question #32
Troubleshooting is good for the soul. Especially if you can finally solve the issue once and for all. You will feel like you are on top of Mt. Everest. :)
Well, jumped to conclusions. Since the relay failed the first time I just assumed it failed again. Turns out it is fine. Had a ground wire issue. Go figure.
Thank you everyone for the troubleshooting advice.
Jeff
/ Electrical Relay Question #35
Jeff
Well, now that you have solved it, do you feel better?:)
You bet! Nice to have my work lights back too. With the day's getting shorter my mid week seat time is shrinking.
/ Electrical Relay Question #37
At what location did you find the faulty ground connection?
Glad you got it fixed.
I simply loosened a bolt underneath and slipped the wire under the washer. Should have made the effort to scrape off to bare metal and use a connector the FIRST time. Live and learn, eh.
/ Electrical Relay Question #39
As an old timer, I always suggest scraping to bare metal and I always coat that bare metal with No-Ox-Id. I don't know that it is more magical than ordinary grease but in over 30 years of using it, nothing I have ever put it on has corroded. I have used it in all sorts of automotive and antenna and battery/ground applications.
2018 Ford Fusion Hybrid Sedan (A59231)
2018 Ford Fusion...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
2021 Kubota MX5400 (A60462)
2021 Kubota MX5400...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
