Electrical Question
   / Electrical Question #11
Believe me Bob, batteries can cause all sorts of problems! I personally had one fail on me in a car on the way home from a nightshift once, I'd got to my town, stopped to pick up the morning paper and mail from the post office, got back in the car and tyrned the key...nothing! One of the interplate cells connection had come loose, I opened the battery up later to find out why it was accepting a charge etc but why I couldn't "pull a load" on it.
I also worked with heavy duty auto batteries in hard rock mining machines where batteries took a real beating!
I'd still load test the battery or have an auto parts specialist load test it for you to make sure Bob!
   / Electrical Question #12
Interstate is generally a good battery, have one in a 2000 Corolla for 7 yrs, still good. However as Consumer Reports says, the quality lies not in the brand but in the individual battery; some sizes within a brand are good, some aren't.
Higher CCA batteries are made with closer spaced plates. These close plates can break/touch, making a bad cell/battery.
It is possible, and has been told me by a local battery store guy, that a more old fashioned, lower CCA battery may last longer in a tractor with its vibration, bumps, etc.
Mike
O.K.-- I stopped at the Interstate Battery store (regional operations center)-- they took my 6 year old Battery on trade and sold me a "gently" used unit. Brought it home and it started up the Kioti-- no problem!
I still have a the center dashboard "idiot" light lit- Is this telling me anything?
Should I go back and meter the battery with no motor running-- and then meter with the motor- to check alternator output?
BOB P.
   / Electrical Question #14
BOB P.
Yes, its saying your alternator isnt working. Did you ever meter the battery running and not running as suggested way back -before you changed your battery? Startup with a new charged battery just means your starter works.
larry
   / Electrical Question #15
BOB P.
Signs now point more clearly to a charging problem, I'd take a hint from that Kioti dealer that suggested the regulator ...{ "you need a regulator. Part # t2305-65602" ....posted by Virgil .}.... perhaps you could buy it from your dealer, or on line ..... anyway ya got a newer battery now, they don't last much longer than 6-8 years anyway..good luck
   / Electrical Question #16
regulator.... battery is ok..wires and cables and connections are ok...
put a regulator on it.
Sorry for the delay and the cryptic clues to this issue.
Put the meter on the unit tonight-- 12.5 volts
Started the Kioti-- it dropped down to 12.38
Checked all cabling- cleaned terminals etc... no change.
Is it leaning to the regulator? :confused:
BOB P
   / Electrical Question #18
BOB P
That's a big yes Bob, go ahead and call on a price for that regulator..good luck..
   / Electrical Question #19
BOB P
At this point it could be either the regulator not feeding appropriate Voltage to the alternator Field Coil so the alt can generate power, or actual problems with the alternator itself. If there is a terminal on the alt marked "F", you should measure several volts from there to ground with everything connected and the engine running if the regulator is working. The next thing is tosee if there is actually current flowing into the Fld coil by removing the wire and seeing if it sparks when you reconnect. If the Fld is drawing current and youre not getting alt output, its the alt diodes or a stator problem. Sorry the info is so general. I think Virgil has specific experience with your model
   / Electrical Question #20
Bob, it looks like your alternator must have seen an open circuit in the battery at one time. When this happens there is no way the regulator could see a reference voltage, so therefore the alternator voltage rose to a point where it blew either the diodes in the regulator/alternator pack, or the transistor in the regulator circuit. Seen that happen thousands of times.
All you can do is replace the regulator/alternator if it's built in. I have never seen windings on an alternator burnt out due to open circuiting the charging circuit.
But at 6 years, you've had a good life out of that battery!
Check the voltage at the battery with the engine running, it should be 13.8volts approx, might be slightly higher. If below 13, then you have an alternator/regulator problem, probably caused by the bad battery.
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
2018 John Deere 4066R (A53314)
2018 John Deere...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A57880)
2018 VOLVO VNL...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
