Electrical Problem with Kubota L3130
   / Electrical Problem with Kubota L3130 #11
Generally "system" power is taken off directly at battery terminal (second wire to/at main cable to starter) or a double up connection on terminal on starter solenoid.... Anyway whatever point the power is tapped off of it usually goes to a "master" fuse or fusible link on newer tractors that powers up everything on tractor....
   / Electrical Problem with Kubota L3130 #12
This morning I had the same problem with the same model tractor -- checked battery and fuses -- still nothing -- totally dead. I came in for lunch and found your post and the problem was solved by just cleaning the one electrical connection.
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
GARDNER DENVER 480 VOLT AIR COMPRESSOR (A50854)
GARDNER DENVER 480...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
Quick Attach EZ Axe Skid Steer Tree Shear (A51039)
Quick Attach EZ...
