Electrical Problem - 2220D
/ Electrical Problem - 2220D #11
"I've replaced the battery, rebuilt the starter, replaced the ignition switch, checked the wiring for wear and checked the fuses."
The battery was one of the first things he threw at it. Same problem.
/ Electrical Problem - 2220D #12
Had Battery problems a few months back on a 07 Lariat. The repair shop that put it in swore the battery was good and the Veh. had a electrical problem. They stated it could be Big $ to find it and correct the problem. The previouse owner's son had a upgrade on the stereo so they had the shop that installed it checked for problems and they claimed every thing was in Ex. working order. The owner had me go help pick it up and sure enough it wouldn't start. Jumped it and off to the Dealer it went. In or around about 3-4 days later it was ready to pick up. When asked if they found the prob. they replied yes it was the Battery!!!
Thanks everyone for your input and for preventing me from spending several hundred dollars on parts I don't need. I cleaned and re-tightened the chassis ground wire from the negative battery terminal and my old Yanmar is running like a champ again! I forgot my own troubleshooting advice, do the simplest things first. Thanks again.
/ Electrical Problem - 2220D #14
Thanks for the update!
Scott
2018 ALLMAND MP40-8BI-PORTABLE DIESEL GENERATOR (A59823)
2018 ALLMAND...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2023 Global Trailers GT302 60YD T/A End Dump Trailer (A59230)
2023 Global...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
