electrical connectors
/ electrical connectors #1
kclark2227
Kannapolis, NC
Kubota L4701 4WD HST
Does anyone know if there is any type of splitter for this type of connector?
My FIL is trying to wire up a backup camera to the Kubota (why? well I know why but I personally still wonder really??? why?). But anyway he is paying for the tractor so I have no choice but to figure out how to make it work. If I can find some sort of splitter then I can fairly easily install it.
/ electrical connectors #2
All you would need to do is crimp two wires into this connector.
or this
/ electrical connectors #3
Radio Shack carried double females in small packs. Probably would have to buy a full box online now.
/ electrical connectors #5
What Radio Shack?, thought it went under, most store's locally closed....
Best bet may be adapter that slips in to fuse holders If trying to hook up power or just peruse auto parts store electrical connector selection and hopeful to find something that fits your needs....
Here it comes, the phrase nobody wants to hear... Try GOOGLE IMAGES, search string "wire connectors" If you see something that looks like it will work for you, chase it do supplier and hopefully it will be available and as reasonable cost......
For most electrical stuff I use places like...
Del City - Electrical Supplies & Professional Grade Wiring Products
or
Waytek | 12V Electrical Components Distributor
Look in sections for "connectors"...
Dale
I wound up doing doing things the dirty way until I can get the connectors in. I now have the backup camera monitor wired up along with a camera mounted to the grill guard and one on the rear. All is working fine.
/ electrical connectors #10
If I understand right, you need to take that one male spade and end up with 2 male spades - if so this should do the trick. Just google around with the part number to find your best deal.
https://www.molex.com/molex/products/datasheet.jsp?part=active/0190430010_QUICK_DISCONNECTS.xml
Allied has them for 10 cents each.
1943-:) at Allied Electronics & Automation, Inc
/ electrical connectors #11
Yes, I have seen many styles, but as suggested, making your own Y is the easiest and maybe even best for integrity.
/ electrical connectors #12
Landhonor Quick Attach Log Grapple (A66285)
Landhonor Quick...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
International 574 Loader Tractor (A66285)
International 574...
Wooden rocking horse (A64557)
Wooden rocking...
Landhonor 31" Mini Excavator Bucket (A66285)
Landhonor 31" Mini...
