Electric switch pto
   / Electric switch pto #1
tbibbs00
Montana 5740C
I have a 5740C, the pto switch will not turn off. The tractor will not start with the pto turned on. Anyone have suggestions?
   / Electric switch pto #2
Replace the switch. Pull the wires off the switch so you can use the machine.
Thanks, Is this a common thing with the pto switch?
   / Electric switch pto #4
Try a TBN "search" with your Montana Mdl# and see if anyone else has reported simular issues.
Boone
   / Electric switch pto #5
My 2007 5740 has a dfferent problem with the PTO switch. It will not activate the Manual mode. It still functions in OFF and continuous though. I suppose I ought to get a switch on hand before I get stranded.
As a second thing to check before replacing the switch, look for wiring damage from rodents or other damage first.
   / Electric switch pto #6
I know that if the pto switch is on, the starter will not turn the motor over to start. That is a safety, that is built into the unit. The pto switch is wired into the clutch pedal switch, which in turn goes to the starter solenoid . As far as the pto not turning off, That is a new one to me. Usually, they won't engage, which is usually a wiring issue. I suppose, a switch could go bad, but haven't seen that to often. Maybe, you'll get lucky with a new switch, but I have my doubts. I'll have to check the wiring diagram, as I have not had many issues, of this kind, locally.
2018 FORD F-150 (A52472)
2018 FORD F-150...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2013 CHEVROLET SILVERADO 1500 (A52472)
2013 CHEVROLET...
2019 RAM 3500 (A52472)
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
