electric compressor motor
/ electric compressor motor #1
bjr
Veteran Member
Eastern WA
Jinma JM354
I apologize if I'm in the wrong forum but I use my compressor a lot and the motor quit. Kept tripping the breaker. It's worked fine for about twenty years. It's a 5 hp single phase reversable 230 volt Ajax motor. Ajax motor company no longer in buisness, of course. It's got two start capasitors and two run capacitors. I check with ohmeter and found one start bad it did differently from the other in that it wouldn't go up scale. Even with the new cap. no go, just hums. I checked with local motor shop and he said maybe a stationary switch may be the culprit. I guess the motor has two switches one stationary and one rotary to take the start winding out of circuit. My question is do I stand a chance of finding replacement switches? I mean are they generic or manufacturer specific? A complete motor replace is over $500 way more than I gave for the original complete compressor. A wiring schematic showing the two start and two run would be helpful also. There's a small diagram on motor but too small for me to see. bjr
/ electric compressor motor #3
Graingers has many compressor motors. You already have the volts, just get the rest of the motor specs off the tag (such as rpm, frame, amps, etc) and match up a standard replacement motor. I think TSC and Northern tool have compressor motors also.
Grainger Industrial Supply
/ electric compressor motor #4
5HP is a pretty large single phase motor. I would take it to a motor shop and ask them. If its the start switch then it should be a minor item. If the windings are burnt out then it will get pricey....
Udate on the compressor motor. I had electrician buddy come try to fix it and he took the end cover off and blew out 32 yrs of dirt and dust. He said the contacts in the stationary switch look as though they should function okay. Then we check the capacitors again with a scaling fulke meter and they appeared okay. Now I think the motor shop I talked to said they had a dedicated capacitor testing equipment. So our test with the ohmeter may have not not been conclusive. We did get the compresser to turn at low speed but not come up to speed. I don't know if that means the start circuit is okay and something in the running circuit not okay? I didn't try ohming the motor run windings. Any thoughts here on the motor not coming up to speend? Remember there two start capacitors and two run capacitors here. bjr
/ electric compressor motor #6
Did you try starting it with the belt off?
Dose the centrifugal switch arms or weights move freely when you had the end bell off?
Can you see the switch move when it starts up?
It sounds like its staying in start mode ot the start winding is open
here is a link to read through. Electric Motor Basics
and motorsanddrives.com - Motor Types
tom
The guy I had look at it said all that (centrifugal and the stationary switch) was working as it should. It's at a motor shop now, we'll see what that guy says. I get back as soon as I know something. bjr
/ electric compressor motor #8
We are assuming that the compressor pump is not binding up ...
jb
Compressor turned fine. I just did get a call from the shop that I took it to and he said they tested every thing on the motor, IE windings and capacitors, and put everything back together and it started just fine. Maybe I got a capacitor wired wrong, I've been wrong before when I thought I had things wired right that were not. I'll pick it up tonite and see what happens. bjr
2021 BOBCAT T76 R-SERIES SKID STEER (A65056)
2021 BOBCAT T76...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
27001CFL (A66736)
27001CFL (A66736)
DIAMOND TOOLBOX (A68842)
DIAMOND TOOLBOX...
2017 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A66736)
2017 Eager Beaver...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A68183)
1987 Polar 307 SS...
