electric brake controllers?
/ electric brake controllers?
Ok I bought the P3, hope I didn't make a mistake. Should I have bought the Max for 3x the price, I guess I'll find out. Just like you, I don't use the trailer much. I am looking for a dump trailer, but it will mostly be used for light loads like mulch.
The big and ugly factor didn't have any part in my decision. I am more concerned with how well it works over appearance. Though I do understand.
The P3 has done very good in our f-650 since I put it in about a year ago, it gets loaded 20-30k lbs loaded each week on 48' drop deck with 15k electic over hydraulic brakes. Brakes get a work out in Houston traffice and truck averages 600-800 miles per week. When it starts to act up, think I wll try the max out and see. I like the fact its tied in the hydraulic brakes, kind of like the the old vacuum over hydaulic trailer brake setups.
P2 is going my pickup next week
/ electric brake controllers? #42
i pull a 14k deckover gn and a large box trailer often... prodigy works fine for me!
/ electric brake controllers? #43
I have a Hayes in my 1/2 ton Chevy. Works fine, I do not tow a lot or real heavy loads. Usually 6-7k lbs at most a couple times a year.
/ electric brake controllers? #44
2) It's ugly and big. Mounting it inside the cab will not leave a result that's eye-appealing.
As far as big and ugly goes the Brake Smart unit is smaller but looks are a matter of opinion :D
/ electric brake controllers? #47
Well, if you're basing things on market research, then maybe this is the best one available......
TruControl Silver Features List
Gotta love their "FAQ"
http://www.trucontrol.com/news/brake_controller_better_braking_report.html said:
Amperage isn’t the only factor. Remember that trailer brakes wired in series experience uneven braking and wear. By keeping all our wires to the brakes the same length, we guaranteed equal power to each brake, and equal timing. When I slammed on the brakes at 60mph, I didn’t get the usual lurch to one side that I did before the upgrade. The trailer maintained a perfect track behind the tow-vehicle.
Apparently they didn't get the memo that electrons travel at 186,000mi/sec, so as long as they had heavy enough wire to handle the amp draw and they aren't daisy chaining the magnets (ie: the output of one magnet goes to the input of the next) it doesn't matter (within reason) how long the wires going to the magnets are or how much difference there is in wire length.
Aaron Z
/ electric brake controllers? #49
I agree. I thought the couple I installed looked great.
Chris
/ electric brake controllers? #50
Aaron Z
as long as you don't get ridiculess on length and start introducing voltage drop or inductance.. it should be fine if one wire was say.. 6' and the other 10' etc.. etc.. etc.
/ electric brake controllers? #51
Aaron Z
Actually, electricity does not flow at the speed of light. It's MUCH slower. It's more on the order of 8-9 centimeters PER HOUR.
Wire lengths DO matter, but only if you're working with differences in length that are significant. Over a 30' run of wire, a few feet of difference is not even measurable. As long as all of the wiring is the same gauge, and the lengths are all within 10-15% of each other, there is zero measurable difference in how quickly a brake will react.
/ electric brake controllers? #52
Because it makes it a pain in the *** to maneuver your trailer, that's why!
It's usually counter-productive to have your trailer brakes activating when reversing. Your truck should easily be able to handle all the braking needs for reversing which you probably do at no more than 10 MPH. If it can't, how are you going to stop your rig if it's going forward down the highway at 60 MPH and the trailer brakes stop working?
i agree.. I was trying to back my trailer into a loading bay and the shop yard was gravel, and the bay was 1' wider than the trailer. stepping on the brakes made the brakes grab more int he gravel on one sid ethen the other making me go in crooked till I realized I still had brakes dialed in on my drawtight. once I zero'd brakes I got in in 1 try like normal. for a moment I thought I had forgotten how to back a trailer.. was kinda embarrising witht eh guys at the loading dock wondering why I couldn't get the trailer in like i did all the time..
With a straight time-delay controller, I could see where this would be huge pain. My P3 works with inertia sensors to control how MUCH brake force is applied, and I always set the brake force for the load on the trailer. So, I haven't gotten bitten by that sort of scenario (at least, not yet).
/ electric brake controllers? #53
Odd, everything I have read (including a wiki article that I looked at to double-check) says that on uninsulated copper wire, electrons flow at over 90% of the speed of light... Otherwise computers flat out wouldnt work.
Aaron Z
/ electric brake controllers? #54
Just out of curiosity has anyone ever seen or heard of a cheap brake controller failing? I have heard of plugs falling out and one friend shorting a brake wire to ground (but it was designed with short protection so it didn't hurt it) but none actually failing. I'm wondering how often it happens?
I bought my P2 years ago and I bought it because I like the feature of not having to adjust it when it stop and go traffic. I hate messing with hydraulic lines, I always make a big mess, otherwise I would look at the Max unit to see what extra benefits it offered. But I also have a basic unit that had worked every time I needed and would still be in use today. I bet it cost $25 back in the day. It was only replaced because I got a three axle equipment trailer and I wasn't sure if it was able to do more than 2 axles.
/ electric brake controllers? #55
Electrons are not electricity. Electrons, in a vacuum, travel at essentially the speed of light. When those electrons are "stacked up" on/in a wire in the form of electricity, they bounce all over the place and crash into other electrons. The resultant "speed" that they move from one end of the wire to the other is significantly reduced.
Law of diminishing returns... If you can accomplish 99.999% of the jobs for cost "X", why would you spend "3X"? For the "average" person, the standard units like we're discussing here for $100 or so will do the job every time.
/ electric brake controllers? #56
Think about it this way...
You have a 100' hose that holds an exact number of drops of water when "full". The hose is currently full.
You add water to one end of the hose at the rate of one drop per second.
How long does it take for any one specific drop of water to travel through the hose and come out the other end?
Similarly, how long will it take for *ANY* drop of water to come out the other end as you add a drop to one end?
The difference in these answers is the difference between the flow of electrons through wire and the "speed" of electricity.
/ electric brake controllers? #57
As I understand it, the electrons are like standing water in a pressurized firehose. When you open the valve, the exact molecule that you send out may take a little bit to come out, but you will get have 1 electron out the other end of the wire with a delay of ~the speed of light from when you send 1 in.
Aaron Z
/ electric brake controllers? #58
I have seen as many of brand X fail as brand Y. Its usually just a simple matter of them not powering up and most of the time I get them they have been installed improperly.
I have had the same Reese Tow Master Timed unit in 5 different F-150's, a Mountaineer, and now my Titan. It has to be 15 years old. Never a hiccup.
Chris
/ electric brake controllers? #59
True, but my point was that the length of wire (within a reasonable difference of 2-15 feet as could be seen in a trailer brake connection) will not make any appreciable difference of how fast the trailer brakes are applied (assuming that the wires are sized properly).
Aaron Z
/ electric brake controllers? #60
I keep everything until it quits. The original controller I put in my 1990 F250 quit and was replaced about four years ago. The controller in my 1991 F250 did the same a year later. I've never really been happy since I got rid of my previous truck which was plumbed into hydraulic brake pressure to determine braking force. After reading this thread I'm going to look into some of the better units which I wasn't aware of until now. I'm never over 18,000# gross combined.
2015 John Deere 35G Mini Excavator (A62613)
2015 John Deere...
2005 John Deere 7320 (A60462)
2005 John Deere...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
2007 HEIL TRAILER (A65643)
2007 HEIL TRAILER...
