Elect/Hydraulic Dumping Trailer
/ Elect/Hydraulic Dumping Trailer #1
mwells4654
Antlers, Oklahoma
International 404 & Shibaura SD2600
I have a small dumping trailer that currently is a power up gravity down and I want it to be power up/down. The cylinder is dual but only has one hose going to it from the electric pump assenbly. What would be the easiest way to convert the system? Thanks in advance for any advice.
Melvin L. Wells Jr.
/ Elect/Hydraulic Dumping Trailer #2
2 hoses and 1 spool valve and a return to the reservoir
/ Elect/Hydraulic Dumping Trailer #3
What kind of valve are you using now.
If it is a SA spool, then you have to get a DA valve.
If it is a DA spool valve, then remove the plug from the one work port and use two hoses to the cyl.
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
Duratech HD 8 Tub Grinder (A62613)
Duratech HD 8 Tub...
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
NEW 2025 Trailer by Premiere 18'+2' Tandem Axle (A62679)
NEW 2025 Trailer...
