Elbow fitting size for hydraulic top link cylinders
   / Elbow fitting size for hydraulic top link cylinders #1
Indian Territory
New Holland PowerStar 75
I‘ve done a search, and seen this topic discussed…sort of, but I’m still uncertain what to order. I am needing right-angle elbow fittings for connection to my remote-attached top link hydraulic cylinders. Are those typically a standard size?
   / Elbow fitting size for hydraulic top link cylinders #2
The exception that I hear about occasionally is British pipe thread instead of NPT.
Thanks. Do you know if the fittings are typically a standard diameter?
   / Elbow fitting size for hydraulic top link cylinders #4
I would say that 3/8" NPT or -6 size if they are SAE O-Ring ports is more common than not. A couple pics with some dimensions would be useful.
   / Elbow fitting size for hydraulic top link cylinders #5
If you already have your cylinder(s), this might help you figure it out - if not, yours could conceivably be 3 different possible sizes of at least 4 different fitting types - so without the cylinder or at least a spec sheet on the cylinder, you have about 1 chance in TWELVE of getting it right...
Regardless, here's a link to a helpful PDF you will likely need more than once -
FREE Thread ID Guide here - hydraulic
HTH... Steve
   / Elbow fitting size for hydraulic top link cylinders #6
Also referred to as 9/16-18 thread oring base
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
Irrigation Pump with John Deere 4045 Engine (A52128)
Irrigation Pump...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
CLASS ROLLANT 160 HAY BALER (A51243)
CLASS ROLLANT 160...
1974 Ih Farmall 1066 Tractor (A50514)
1974 Ih Farmall...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
