Elbow fitting size for hydraulic top link cylinders
   / Elbow fitting size for hydraulic top link cylinders #1
Indian Territory
New Holland PowerStar 75
I‘ve done a search, and seen this topic discussed…sort of, but I’m still uncertain what to order. I am needing right-angle elbow fittings for connection to my remote-attached top link hydraulic cylinders. Are those typically a standard size?
   / Elbow fitting size for hydraulic top link cylinders #2
The exception that I hear about occasionally is British pipe thread instead of NPT.
Thanks. Do you know if the fittings are typically a standard diameter?
   / Elbow fitting size for hydraulic top link cylinders #4
I would say that 3/8" NPT or -6 size if they are SAE O-Ring ports is more common than not. A couple pics with some dimensions would be useful.
   / Elbow fitting size for hydraulic top link cylinders #5
If you already have your cylinder(s), this might help you figure it out - if not, yours could conceivably be 3 different possible sizes of at least 4 different fitting types - so without the cylinder or at least a spec sheet on the cylinder, you have about 1 chance in TWELVE of getting it right...
Regardless, here's a link to a helpful PDF you will likely need more than once -
FREE Thread ID Guide here - hydraulic
HTH... Steve
   / Elbow fitting size for hydraulic top link cylinders #6
Also referred to as 9/16-18 thread oring base
2016 Chevrolet Silverado (A50323)
2016 Chevrolet...
2007 CATERPILLAR 303.5C CR EXCAVATOR (A51242)
2007 CATERPILLAR...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
8-Shank Cultivator (A52128)
8-Shank Cultivator...
Wolverine Quick Attach 80' Bucket (A50514)
Wolverine Quick...
Walking Floor Trailer (A50322)
Walking Floor...
