Elbow fitting size for hydraulic top link cylinders
   / Elbow fitting size for hydraulic top link cylinders #1
Indian Territory
New Holland PowerStar 75
I‘ve done a search, and seen this topic discussed…sort of, but I’m still uncertain what to order. I am needing right-angle elbow fittings for connection to my remote-attached top link hydraulic cylinders. Are those typically a standard size?
   / Elbow fitting size for hydraulic top link cylinders #2
The exception that I hear about occasionally is British pipe thread instead of NPT.
Thanks. Do you know if the fittings are typically a standard diameter?
   / Elbow fitting size for hydraulic top link cylinders #4
I would say that 3/8" NPT or -6 size if they are SAE O-Ring ports is more common than not. A couple pics with some dimensions would be useful.
   / Elbow fitting size for hydraulic top link cylinders #5
If you already have your cylinder(s), this might help you figure it out - if not, yours could conceivably be 3 different possible sizes of at least 4 different fitting types - so without the cylinder or at least a spec sheet on the cylinder, you have about 1 chance in TWELVE of getting it right...
Regardless, here's a link to a helpful PDF you will likely need more than once -
FREE Thread ID Guide here - hydraulic
HTH... Steve
   / Elbow fitting size for hydraulic top link cylinders #6
Also referred to as 9/16-18 thread oring base
2020 KOMATSU PC360LC-11 EXCAVATOR (A51242)
2020 KOMATSU...
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
HOWSE 67" BOX BLADE W/ SCARFIER (A51243)
HOWSE 67" BOX...
FUTURE SKID STEER QUICK ATTACH TRENCHER (A51243)
FUTURE SKID STEER...
