EHydro diagnostic flash codes
/ EHydro diagnostic flash codes #1
Dave4410
Cape Cod
2004 John Deere 4410 eHydro
Can anyone tell me what 2 short & 2 long flashes indicate?
/ EHydro diagnostic flash codes #2
Well I'd call the dealer and ask... If you want to do a search here is the electronic version of the manual online. 4X10 Manual
/ EHydro diagnostic flash codes #3
Jason Ubertek at K.C.Canary addressed this:
<font color="green"> Short, long, long, short or .--. is indeed the fault code for the mfwd sensor . If you have cruise control it will not function. The flywheel speed sensor is also the same part # as the mfwd sensor. So in my opinion the flywheel speed sensor could possibly fail, Their is an internal wiring problem inside certain speed sensors. Deere has corrected the problem with a fix as fail . This doesnt mean that everybody with e-hydros has to worry, not everybody will experience this. contact your dealer. The kit consist of both the mfwd and flywheel sensors and take about 5 minutes to install. </font>
When I had this, restarting the tractor resoved it.....
/ EHydro diagnostic flash codes #4
11 • • - -
(S/N
H120713 -
H131964 -
H141272 -
Sensor supply
voltage
Normal Operation:
Voltage is out of range. No drive in either
direction.
Power recycled through off
to clear error status.
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A59912)
2019 INTERNATIONAL...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
Zuidberg Front 3pt and PTO Kit (A63117)
Zuidberg Front 3pt...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
