EHydro diagnostic flash codes
/ EHydro diagnostic flash codes #1
Dave4410
Cape Cod
2004 John Deere 4410 eHydro
Can anyone tell me what 2 short & 2 long flashes indicate?
/ EHydro diagnostic flash codes #2
Well I'd call the dealer and ask... If you want to do a search here is the electronic version of the manual online. 4X10 Manual
/ EHydro diagnostic flash codes #3
Jason Ubertek at K.C.Canary addressed this:
<font color="green"> Short, long, long, short or .--. is indeed the fault code for the mfwd sensor . If you have cruise control it will not function. The flywheel speed sensor is also the same part # as the mfwd sensor. So in my opinion the flywheel speed sensor could possibly fail, Their is an internal wiring problem inside certain speed sensors. Deere has corrected the problem with a fix as fail . This doesnt mean that everybody with e-hydros has to worry, not everybody will experience this. contact your dealer. The kit consist of both the mfwd and flywheel sensors and take about 5 minutes to install. </font>
When I had this, restarting the tractor resoved it.....
/ EHydro diagnostic flash codes #4
11 • • - -
(S/N
H120713 -
H131964 -
H141272 -
Sensor supply
voltage
Normal Operation:
Voltage is out of range. No drive in either
direction.
Power recycled through off
to clear error status.
UNUSED WOLVERINE SB66-66" ROCK BKT (A64281)
UNUSED WOLVERINE...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRACTOR (A59911)
2014 FREIGHTLINER...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
CUSHMAN REFRESHER GAS GOLF CART (A63276)
CUSHMAN REFRESHER...
2007 Ford Crown Victoria Sedan (A61574)
2007 Ford Crown...
