EHydro diagnostic flash codes
   / EHydro diagnostic flash codes #1
Dave4410
Cape Cod
2004 John Deere 4410 eHydro
Can anyone tell me what 2 short & 2 long flashes indicate?
   / EHydro diagnostic flash codes #2
Well I'd call the dealer and ask... If you want to do a search here is the electronic version of the manual online. 4X10 Manual
   / EHydro diagnostic flash codes #3
Jason Ubertek at K.C.Canary addressed this:
<font color="green"> Short, long, long, short or .--. is indeed the fault code for the mfwd sensor . If you have cruise control it will not function. The flywheel speed sensor is also the same part # as the mfwd sensor. So in my opinion the flywheel speed sensor could possibly fail, Their is an internal wiring problem inside certain speed sensors. Deere has corrected the problem with a fix as fail . This doesnt mean that everybody with e-hydros has to worry, not everybody will experience this. contact your dealer. The kit consist of both the mfwd and flywheel sensors and take about 5 minutes to install. </font>
When I had this, restarting the tractor resoved it.....
   / EHydro diagnostic flash codes #4
11 • • - -
(S/N
H120713 -
H131964 -
H141272 -
Sensor supply
voltage
Normal Operation:
Voltage is out of range. No drive in either
direction.
Power recycled through off
to clear error status.
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
