Front-End Loader ed price
/ ed price #1
ed price
huntsville ut
Branson
I have a Branson 4720i I use for small jobs. The glow plugs quit working and I'm trying to locate a wiring diagram. The owners/repair manual that came with the tractor has nothing in it about the glow plugs except to tell me there is a light on the dash. Big help.
Any idea where to get a wiring diagram?
Thanks,
Ed
/ ed price #2
I'm not familiar with Branson. Glow plugs typically are a simple circuit. Power runs from the battery to a fuse or fuse block, then to a switch, then to the glow plugs. Mine are in series like those annoying christmas lights. Ultimately the other end grounds. Series circuits can be fussy. Nominal 12 volt power should divide equally, 4 glow plugs each get 3 volts. If they are not exactly matched they may not share voltage equally the one with most resistance gets most voltage. All will get equal amperage. Amps times volts equalls watts. Watts are the measure of power. A heater with more power generates more heat. This isn't always a good thing. Too hot it isn't for long, then it's burned out. Replace one, the cycle begins anew, burning out a different one. Eventually even the new one you first replaced becomes the high resistance one and it burns out. If you have one burned out, and yours are in fact in series, not parallel, replace them all.
These are low voltage high amperage circuits. They are prone to failed connections. Use an ohm meter to take each component out of the circuit and test, or use a volt meter or even a 12 volt incandescent bulb with wires to check across each component's two terminals.
/ ed price #3
Hi Ed,
Welcome to TBN!
You will likely have more luck if you repost this with a descriptive subject like: "Need Branson #xxxxx wiring diagram" or "Branson #xxxx glow plug problem".
The other hint is to post it in the Branson Owning forum, or if there isn't one, in the Other MFG tractor forum.
Good luck, have a safe and happy holiday, and safe trractoring,
Thomas
Thanks,
Ed
2008 Chevrolet C4500 Truck, VIN # 1GBE4V1998F404142 (A61165)
2008 Chevrolet...
John Deere 6300 (A60462)
John Deere 6300...
UNUSED GIYI HYD AUGER SET (A62130)
UNUSED GIYI HYD...
2844 (A58376)
2844 (A58376)
2009 Ford E-350 Cargo Van (A61568)
2009 Ford E-350...
2025 Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Hydraulic...
