Ecoboost question for DP
/ Ecoboost question for DP
Yea I am fully aware that DPF's are a diesel thing, and all of the big three use DEF now as opposed to an extra diesel injector in the exhaust for "regen". THe claim is the mileage numbers are back up because of it, but you are still using some sort of fuel, do DIESEL mileage s back up but factor in the cost of DEF and it mitigates that somewhat. Although DEF usage is not as high as was diesel fuel for regen purposes.
Unburned gas, unburned particulates, it's still making up for incomplete combustion.
/ Ecoboost question for DP #42
My only experience with DPF is on our company 2014 Dmax trucks. They need a 2.5 gallon jug every 3000 to 4000 miles, but to be fair they idle alot. The other experience is with my neighbors 2012 Power Stroke. His gets 2.5 gallon jug every oil change or about 7500 miles. He also had a Passat diesel and it was about the same usage.
The cost even on the company trucks is negligible at $8 per 2.5 gallon jug. That works out to $ .0027 per mile and on the others it's about $ .0011 per mile.
Chris
/ Ecoboost question for DP #46
That and they no longer use diesel fuel for this process.
Chris
I wish they didn't but they have to use diesel fuel to burn out the soot in the DPF. During a regeneration, the Powerstroke diesel injects diesel just as the exhaust valve is closing to bring the temp in the DPF up high enough to burn out the soot. Depending on whether I'm towing or not, I can go from about 300 to 500 miles before the truck does a regeneration. Takes about 18 miles to complete. Fuel mileage drops to about 8.5 while it's in regen then jumps back up to 16 when it's finished.
/ Ecoboost question for DP #48
My Chevy Cruze goes 500 - 700 miles before regen in the summer but with snow tires, idling in the morning its dropped down to between 300 and 500 miles. Fuel economy in the winter has gone from 49-51 mpg to 39-41mpg i know the snows made a huge difference versus the low rollers that come on it.
Same story DIC 25 mile average will go from say 46mpg down to 31-33mpg for 20 15-20 miles and slowly go back up.
My wife is driving 110-120 miles a day all highway.
/ Ecoboost question for DP #49
What winter tires are you using? We have two Cruze TD's, we have Altimax Arctics and Nokians and the difference is pretty small.
The new diesels do in fact have one additional fuel injector in the exhaust down pipe.
Duramax Diesel Exhaust System Fluid Injectors - GM Techlink
Yea I misstated that, they no longer have a diesel fuel injector, it's for the DEF and yes they do regen, but not with diesel fuel, so it keeps the mileage numbers up.
7500 miles is a long time between DEDF fill ups so that is a bit better than I have heard. DP for your company trucks, excessive idling DOES really cause more frequent regens, from what I have heard. Lower exhaust temps cause more soot build up in the DPF.
/ Ecoboost question for DP #52
My understanding is that while they still use diesel fuel to regen the DEF lowers the temperature required for the regen and thus lowers the amount of diesel fuel being injected.
/ Ecoboost question for DP #53
How do you like your diesels?
I run Michelin x-ice 3 supposedly green x lower rollong resistance.
In normal rural off highway driving 55 mph i only see about a 4-5mpg shift. 70mph is definitely 7-9 mpg though. Im sure that remote starting in the cold doesn't help her tank averages.
A guy at work put 18" Verano take off wheels and an all season tire on his diesel cruze the day after he bought it. He couldn't figure out why he was getting only 35 mpg even after 3000 miles. he brought it into the gm proving grounds where they did a fair amount of testing looking for issues finally they decided to do an A-B-A-B test on the 18" goodyear eagle ls and the stock good year. They drove 70 mph around the circle track. Which is 4.7 miles they reset the odo once up to speed and made several laps. What they found was the eco tires got between 5.5 -6 mpg different at 70 mph they got nearly identical results both times.
I had Michelin harmony tires on my saturn but i ran Bridgestone blizzaks WS60's on the car in the winter i didn't install them until needed such that i would wait until after the switch to winter blend and i would go from 38 mpg down to 34mpg after the switch this was my normal rural 55mph commute. The harmony tires were not a low roller either so it. I saw similar % reduction on the grandprix going from good year assurance tripple treads to blizzak ws70's.
In both cases these were shifts from standard all seasons to snow tires.
Thus it stands to reason that one can expect a fairly large change going from an ultra low rolling resistance tire to a snow tire.
/ Ecoboost question for DP #54
I am curious, was the inflated diameter the same between summer and winter tires?
I see a noticeable difference in mpg on my car (2-3 mpg less in the winter) and have noticed that the inflated diameter is different by 0.5" and my speedometer goes from being right on to reading 2-3MPH faster than my ground speed (per the GPS on my phone).
Aaron Z
/ Ecoboost question for DP #55
Lots of misinformation here about regens.
First, yes, the new diesels do still regen, and yes the DO use diesel fuel to regen. DEF is not flammable and won't burn to heat up the DPF to burn off the soot. DEF is (I think) 67% water, the rest is a mixture with a lot of ammonia in it.
Second, DEF is used to lower NOx emissions in order to meet emissions regulations. All trucks with DEF us a special DEF injector to inject DEF into the exhaust to mix with the NOx. The chemical reaction breaks down causes the NOx to combine with the NH4 in the DEF to produce water vapor.
Thirdly, DEF itself does not affect regens and in no way is it tied to regens. However, the use of DEF to reduce NOx allows the trucks to run less EGR, thereby running a bit higher combustion temperature, resulting in less soot buildup in the DPF, which in turn requires less regens. More infrequent regens leads to better fuel economy. Make sense?
They may not be 100% correct, but it is a lot closer than some of the other posts. :)
Also, GM puts a 9th injector in the exhaust (in the DPF maybe) for the Duramax to inject fuel into the DPF whereas Ford uses an extra injection in the exhaust stroke to get fuel into the DPF. I'm not sure how the RAM Cummins works or Fiat EcoDiesel work.
/ Ecoboost question for DP #56
Aaron Z
Good question I'll have to put my gps in it with the snows to check the speedo.
I know the Static loaded radius was nearly identical only a couple mm difference. the two tires that showed the 5.5-6 mpg difference.
What kind of car and what is the mileage do you normally get.
This was round trip to rose city drove 65 mph on the highway because my buddies trailer was causing his truck to shudder so bad we stopped to check the trailer bearings. Had several trips into town.
At 65 mph my saturn would touch 40 mpg at 65 mph the cruze is in the mid 60's mpg
DIC actually reads low in reality car does between 0.3 mpg better in summer temps or 1.5 better in winter with remote start. The energy engineer says it has to do with remote starting and computer improperly report consumption
With some stop and go around saginasty i mean saginaw. Due to road destruction or whatever MDOT does in Michigan when its not winter.
Same trip
/ Ecoboost question for DP #57
I have a '97 Volvo V90 (RWD wagon with a straight 6). I get 18-19MPG in the winter and 19-21MPG in the summer (depending on how much I play with the skinny pedal).
Aaron Z
/ Ecoboost question for DP #58
I know this is getting off-topic, but it seems people are confusing DPF's (Diesel Particulate Filter . . . this is what needs to 'regen, i.e. burn out the soot), SCR's (Selective Catalytic Reduction), and DEF (Diesel Exhaust Fluid . . . this is injected into the exhaust stream before the SCR and reacts to reduce NOx)
/ Ecoboost question for DP #60
you can easily see it is a downhill situation..........heck have had to do that with a 1993 Jeep Cherokee 6 cylinder and was successful.......but it was downhill like this is...........probably empty trailer so not enough weight on his drive axles.
Kohler Gasoline Air Compressor (A64553)
Kohler Gasoline...
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2021 Bobcat UV34 4x4 Gas Utility Cart (A64553)
2021 Bobcat UV34...
