EcoBoost engine defective?
   / EcoBoost engine defective? #31
Out of curiosity today, I went to the local Ford dealer and counted the total number of F150s and the number of those that were Ecoboost. 13 out of 59. When the Ecoboost was first introduced it was about 50%.
Number on the lot of one dealer has absolutely no correlation with sales numbers.
   / EcoBoost engine defective? #32
Why do they have to give it stupid name like ecoboost. It's direct injection. Lots of cars have direct injection now. It's a technology that came from the high pressure diesels developed in the early 2000. Volkswagen and Bosch invented the high pressure piezo injectors for the tdi, and soon after it started to be used in gas engines. Ford is about ten years behind.
HS
   / EcoBoost engine defective? #33
HS
I believe it also has a turbocharger, hence the boost part.
   / EcoBoost engine defective? #35
The name is just for marketing purposes, the same as everyone else does. It wouldn't be selling in near the same quantities if it didn't have an 'eco' name.
   / EcoBoost engine defective? #36
Anybody priced a set of replacement turbos for that 150,000 mile tune up yet?..
   / EcoBoost engine defective? #37
They're a little cheaper than the turbos for the 100,000 mile tune up of a diesel.
Find me anything from Ford that shows the turbos need to be replaced at 150k miles. I'll make you a bet...a large cup of coffee of the winner's choice. If you can find something that shows the turbos need to be replaced as part of regular maintenance (which is what a "tune up is" at 150k miles, you win. If you don't, I win.
   / EcoBoost engine defective? #38
Yep I did before I bought mine. Seen them online for around $800. Doubt I will reach 150,000 before I sell mine so not a major concern. You needing one? Haven't heard of anyone having failures.
   / EcoBoost engine defective? #39
I do remember reading somewhere from ford that they were designed for a service life of 150,000 miles. But like you that doesn't mean you replace them at that interval. Run them until they fail. Every object in this world will eventually fail. When it does, replace it. Simple enough.
   / EcoBoost engine defective? #40
Precisely! It's called MTBM (mean time between failures). Ford never should have said anything about it, because people see that, and think "oh no, I've got to replace the turbos at 150k!" Truth is, diesels have had turbos for years, and people swear by them. Put them on a gasser and 'oh no!'
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2014 Jacobsen AR3 Commercial Mower (A50322)
2014 Jacobsen AR3...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
2004 TAKEUCHI TB175 EXCAVATOR (A51242)
2004 TAKEUCHI...
