Echo CR352
   / Echo CR352 #11
Saws are normally setup so you need to add oil every time you fuel up, but you should run out of fuel before you run out of oil -- that is an intentional design. If you run out of oil before you run out of fuel, then I'd be concerned. Modern saws are very stingy with oil and generally you can't get close to that situation even with the oiler cranked up.
Almost every saw I own will leave a small puddle after it's been used and put away. Because of this, I have stored saws on a patch of cardboard for as l can remember.
   / Echo CR352 #12
I bought 2 Echo chain saws that have worked well.
I believe the chainsaws come with 5 yr warranty so if yours is still within warranty maybe you can take it to the dealer you purchased it from to have it fixed.
   / Echo CR352 #13
You change bar oil recently? Was using a commercial made winter blend that would puddle to kingdom come. Went back to the husqvarna stuff...no more puddles.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
BLUEHAWK 17CU FT STEEL LAWN MOWER TRAILER (A58374)
BLUEHAWK 17CU FT...
2020 JOHN DEERE 444L WHEEL LOADER (A52709)
2020 JOHN DEERE...
2009 FORD F-250 XL SUPER DUTY FLATBED TRUCK (A58375)
2009 FORD F-250 XL...
2022 Chevrolet Express (A57148)
2022 Chevrolet...
