Eaves through covers to keep the leaves out
   / Eaves through covers to keep the leaves out #12
There are several things offered to keep leaves out of gutters. Two companies, K-Guard and Leaf Guard offer a gutter system with a metal Helmet designed to cause leaves to be diverted away from the gutter while allowing water to enter. Both are pricey. $13.00 -$14.00 dollars per running foot if existing down spouts are used.
Leaf Guard. Good picture showing the separation helmet system. LeafGuard Gutters | LeafGuard of Charlotte | Seamless Rain Gutters
Had a guy a couple weeks ago come out from Leaf Guaed to give us a estimate. Two simple gutters each about 60 feet long.
With tax it came to around $12,000.00
Guess I will still be cleaning my gutters.
   / Eaves through covers to keep the leaves out #13
Took the advice from a contractor and went with 4" downspouts. He smoothed the gutter holes and attached the downspouts. Most everything flushes out with a good rain.
   / Eaves through covers to keep the leaves out #14
Gutter brush - I've been using them for several years now with several maple trees around the house. Haven't had to clean any gutters since I put them in. Much cheaper than the over gutter designs and all you have to do is just drop them in
   / Eaves through covers to keep the leaves out #15
Do your downspouts go into drainage perforated pipe? Dont they just fill up over time, or does yours just flow onto the ground? If so, yes that would probably work very well.
   / Eaves through covers to keep the leaves out #16
When we had some gutter screens put on our gutters; there was a rather humorous miscommunication. Being a pessimist I specified to the salesman that when they installed it I wanted a three foot section of screening over each downspout. My thought was that way if there was a clog I could just remove a short section at the downspout and remove the clog. When the installers came out they did put a three foot section at each downspout, and that was all they installed. The rest of the gutter was wide open. A quick phone call and the error was corrected, but I still chuckle about it. True life representation of the tire swing installation cartoon.
Doug in SW IA
   / Eaves through covers to keep the leaves out #17
Had new eve troughs/downspouts with leaf gutters installed about 5 years ago_One company wanted $3,600 the other wanted $1,600 for the same product.Pays to shop..
   / Eaves through covers to keep the leaves out #18
Doug in SW IA
At my last house and at my rental I cut the downspouts off about 18 inches above ground level and removed the screen at the top of the downspout. Then where the perf pipe came out of the ground I basically made a removable funnel out of PVC adapter fittings (going up in diameter as it got closer to the end of the downspout). I then made a screen in the funnel out of expanded aluminum. Every now and then I pulled the funnel out and banged it upside down on a rock or something to empty it.
Worked quite well for needles. None of my houses have had much of a problem with leaves since we mostly have evergreens here.
   / Eaves through covers to keep the leaves out #19
Go into solid pvc only for several feet.
   / Eaves through covers to keep the leaves out #20
Is the few feet of solid PVC not just just filling up over time without any screen at the top? My idea has always been to keep the leaves/needles out of the downspout AND out of the underground pipe.
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
Rice Hydrostatic Test Pump (A50325)
Rice Hydrostatic...
