Easy way to install plywood clips
   / Easy way to install plywood clips #11
I've never had a problem installing them. put your first row of plywood down, put on clips by the wide side, slide next sheet of plywood down on the clips, repeat after nailing plywood.
It really helps if your sheeting is not warped, nominal thickness isn't too far off and the joist/framing is square/flat, so in other words perfect :). I've noticed more issues with thinner sheeting.
John Deere 6230 Premium with Trebro Sod Harvester (A52128)
John Deere 6230...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
PALLET OF MISC OUTDOOR (A51244)
PALLET OF MISC...
Schuler 220 BF Feed Wagon (A50514)
Schuler 220 BF...
