Easy way to install plywood clips
   / Easy way to install plywood clips #11
I've never had a problem installing them. put your first row of plywood down, put on clips by the wide side, slide next sheet of plywood down on the clips, repeat after nailing plywood.
It really helps if your sheeting is not warped, nominal thickness isn't too far off and the joist/framing is square/flat, so in other words perfect :). I've noticed more issues with thinner sheeting.
CASE TV370B SKID STEER (A51242)
CASE TV370B SKID...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2007 CATERPILLAR D6N LGP HI TRACK CRAWLER DOZER (A51242)
2007 CATERPILLAR...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
SET OF HANG-ON PALLET FORKS (A51243)
SET OF HANG-ON...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51243)
2021 MDB TF150R...
