BaznastyDave
- Joined
- Nov 13, 2023
- Messages
- 37
- Tractor
- Kioti CX2510
Watch me struggle with the valve stem cores blowing out. Rim Guard tire ballast is beet juice which can be corrosive to the glue that holds the metal core inside a rubber valve stem. If your tractor has rubber stems and is filled with Rim Guard I suggest you change your stems to metal.
Colby Valve XL is an extremely easy way to change or repair a valve stem without having to remove the tire. The Colby Valve XL is for 5/8 rim holes in larger equipment.
Colby Valve Permanent Valve Stem will fit any car, truck, SXS, and powersport vehicles with a .453 rim hole.
