Easy Peasy self oil change
   / Easy Peasy self oil change #12
Mine is 4wd and has only one plug.
   / Easy Peasy self oil change #13
Interesting. My Bobcat CT235 has 2 plugs.
It’s 4 wheel drive and HST. I also thought all HST 4 wheel drives had 2 plugs.
Do you all have 2 separate hydro filters?
MoKelly
   / Easy Peasy self oil change #14
Don't use a 5 gallon can, I get mine from a 500 gallon bulk tank with electric pump. Neither of mine fill on the hood anyway. Both have filler necks down low on the left hand side (with a cap of course.) Each hold 30 gallons, give or take.
   / Easy Peasy self oil change #16
MoKelly
Both mine do, one suction and one delivery plus 2 fuel filters and 2 air cleaner filters. Mine aren't 'hydro' in that sense of the word (as in HST). Both are gear drive, hydraulic shuttle. An HST is useless for what I do.
   / Easy Peasy self oil change #18
My DR pump extractor recently broke the line between the one that goes down the dipstick hole and the pump. Bought another one. Have had the DR for years and used for everything. Really handy for the generator where the oil just cannot be drained (a boat inboard would be another).
Your pump looks suspiciously like the "Ironton" pump I bought from Northern Tool. Bought another despite having ruined the seals with hot oil (190 F limit) on the 1st one I bought. Northern refunded my money on that one.
I had ONE incidence where the tube curled up when it hit the bottom of the pan and curled up enough such that it did not suck all the oil out. So, what I do now is mark with my fingers where the dipstick length goes on the dip tube and put it in that length and then very carefully slide it down maybe another 1/4 to 1/2 inch when I maybe feel it hit the oil pan bottom. Only ever happened once.
   / Easy Peasy self oil change #19
Thank you for the good idea about marking the hose length.
   / Easy Peasy self oil change #20
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2013 GREAT DANE  TANDEM AXLE 48FT DRY VAN TRAILER W/CRANE (A59575)
2013 GREAT DANE...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58216)
30 INCH TOOTHLESS...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
