Easy BX23 questions - I hope!
   / Easy BX23 questions - I hope! #1
tshep
Richmond, VA
BX23 MLB
Hi folks, 1st post, been lurking a while.
Couple of BX23 ?'s
A. The book shows the 3PH right hand Lift Rod End (attachment to the hydraulic lift arm)at an awfully strange angle, something like
as though the illustator had never actuall tried to put them on. Looks to me like
makes more sense. Anyone else notice, know why, am I wrong? (Spaces don't come out right, but you get the idea.)
B. The BX came with a thick metal 'T' that might be a hitch hole extender. It seems to be sized to pick up 2 of the hitch bolts, then with the existing hole, use all three for mounting, and extend the base of the T (with another new hole) out about 6 more inches to the rear. It is not listed as an accessory in the literature. Any suggestions as to purpose - would one ever need to extend the hitch hole out to the rear more?
C. And last - what I believe is called a simple Drag Chain Harrow (without any lift pole, no 3PH, no frame, just a hitch bolt, a chain, a drag pole, and 300 lbs of chains and points).... how the heck do you move it around? I understand using it, but between fields, or over driveways, or whatever - how would you keep it from working (unintentionally) without completely taking it off, rolling it over upside down, going wherever, and repeating the process?
   / Easy BX23 questions - I hope! #2
Welcome
A:
If its the dwg on page 39 and41 the right side link the end rod in the top of the turnbuckle is 180 deg out of phase.
I didn't even notice it till you pointed it out but I don't think it will fit the other way any way.
B: picture's please!
C: roll it up and carry it. some rigg a gin pole to lift it off the ground
tom
   / Easy BX23 questions - I hope! #4
Shep, welcome to TBN
Upload some photos. All the exclamation marks on my BX are on warning stickers... :D
Tom - it's like you read my mind (esp. since my diagram wasn't quite right - book in one room, comp. in another!)
More like:
But, yes, it was those pics - I had to try it their way first - a number of times.
I will practice on pics soon.
Will search on 'gin pole' but still, sounds like a lot work to cross a driveway, for instance.
Later, thanks all
   / Easy BX23 questions - I hope! #6
here is a link to one guys rig
its in this link
http://www.tractorbynet.com/forums/build-yourself/153626-my-horse-barn-progress.html
post 26 I think
tom
That looks exactly like the type/brand I have.
I'll figure out the geometry to make that work.
Thanks.
   / Easy BX23 questions - I hope! #8
I think it is based on a tsc carry all to connect to the three point.
tom
About got the chain carry figured out...
Here are pics of previous problems (as attachments?) ...
(DSC is hitch piece, scan is manual page)
So - is hitch peice standard, homemade, seen before (the 'T' butt joint area is only welded one side)? Seem to pick up 3 bolts in 'frame.'
Manual page shows extreme angle at right hand lift?
Thanks all
   / Easy BX23 questions - I hope! #10
The angles in the pictures on the left are correct. They assume a (somewhat) neutral position when the lower arms are spread wide enough for an implement. The adjustable link on the right is mounted backwards in the picture..
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
Toro Z-Master 6000...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A50323)
2015 Ram 3500 4x4...
