Backhoe Easier way to get backhoe on?
   / Easier way to get backhoe on? #11
Now, you need to see the crucial "in-between" stage... Let me describe what's happening and why. The floor jack eliminates the need to extend the boom and dipper to counter balance the backhoe when it's on the stabilizers. Lifting with the foor jack makes the front of the subframe come down from the mounts (after removing the pins of course). This allows you to install the front portion of the dolly (see the photo of the front dolly in position). Once the front and rear dollies are attached, I drive the tractor forward just enough for the rear mount to clear the subframe. Then I let the hoe down off the stabilizers until the front dolly is on the floor. At this point, the stabilizer can be fully retracted. I then let the floor jack down, and then disconnect the hydraulics. You now have a backhoe on wheels with the stabilizers, boom, and dipper fully retracted. I can actually roll it around in the garage by hand. One caution. The entire design boils down to balance. If the rear dolly wheels were any further forward, the front of the subframe would come right off the floor!. As it is, the front dolly has no more than 50 pounds of weight on it.
   / Easier way to get backhoe on? #12
Nice pictures John, and nice dolly for your hoe. I can't help but look in the background, you're giving me serious garage envy!!! Impressive organization /forums/images/graemlins/smile.gif
   / Easier way to get backhoe on? #13
I have been thinking of how to build a dolly that is simple. Any chance that you can share some build drawings with us?
thx...Mike
   / Easier way to get backhoe on? #14
Mike,
Yes, I can probably come up with some drawings, it's just going to take about a week. I'm leaving town this moring, and won't be back until Monday or Tuesday. Maybe I can get something posted then.
John
   / Easier way to get backhoe on? #15
Or, you can just buy a tracked excavator and have one on hand all the time /forums/images/graemlins/wink.gif
Like this one /forums/images/graemlins/laugh.gif
   / Easier way to get backhoe on? #19
John,
Have you had a chance to put together any drawings yet?
Mike
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2016 CATERPILLAR 330 FL EXCAVATOR (A60429)
2016 CATERPILLAR...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
24in pin on excavator tooth bucket (A56436)
24in pin on...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
