Easier tire handling
/ Easier tire handling #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
A recent thread dealt with front tires losing air, and the headaches associated with tubes, patches, etc. When I need to work on anything other than a car size tire, I use this setup: It's simply an existing barn stair post braced well and fitted with a long 1/2" threaded rod and a large wing nut. Having the rim and tire braced against a solid backing makes it much easier to handle and enables me to break the bead using a very large C-clamp. I thought maybe showing the concept would make the job easier for someone else here.
2019 John Deere 4044M (A62177)
2019 John Deere...
Kubota Snow plow with subframe
Kubota Snow plow...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
2016 Ford Fusion Sedan (A61574)
2016 Ford Fusion...
3PT WEIGHT DRUM W/ CONCRETE FILLER (A63291)
3PT WEIGHT DRUM W/...
