EarthForce EF-5 enhancements
/ EarthForce EF-5 enhancements
Re: Mark\'s lucky quarter...
John - I don't know if I'll be able to use that quarter or not - I never have been able to save money... /w3tcompact/icons/smile.gif It'll be amazing enough if I have a quarter, much less that one! /w3tcompact/icons/laugh.gif
MarkC
/ EarthForce EF-5 enhancements #22
<font color=blue>...I never have been able to save money... </font color=blue>
Mark... you've got to be doing something right to have $50-60K to buy that Earthforce and all the add-on's.../w3tcompact/icons/blush.gif
Can you imagine if you started saving money.../w3tcompact/icons/shocked.gif/w3tcompact/icons/laugh.gif
John - Yeah, I can imagine what would happen if I started saving money - I wouldn't have any equipment! /w3tcompact/icons/laugh.gif
MarkC
Well, I settled on the LED lights. I got them from Track Master, Inc. (http://members.aol.com/tmimfg/index.htm). I'm putting the 4" round ones on the EarthForce. I got them in today and tested them, using a 12v power supply - they're super bright! /w3tcompact/icons/cool.gif I'm going to make up some brackets to mount them to the top of the ROPS.
Track Master also makes an equipment flasher that powers up to 20-amp loads and beeps so you can tell when it's on, so I picked up one of those, too, since I had a habit of forgetting to turn the Kubota hazard or turn signal lights off sometimes.
MarkC
/ EarthForce EF-5 enhancements #25
<font color=blue>you might look and see if anyone in your area is running lazer cutters.</font color=blue>
You might also check into water-jet cutting. We use a guy here in town to jet out work for us and it's pennies on the dollar of what it would take us on our Bridgeports. We can also send him .dxf files and he loads them right into his machine. It will cut any material (hard metals, soft metals, glass, ceramic, foam, rubber, wood etc.). Steels up to 2". Another nice benefit is no heat affected zone so post processing is much easier. It won't hold the tolerance of wire burning, but for chain brackets it should be just fine /w3tcompact/icons/smile.gif
/ EarthForce EF-5 enhancements #26
Mark:
On one of the threads, you mentioned the saga of modification of 4 in 1 bucket controls on your Kubota, which didn't quite get to the functionality of the Earth Force system. I have no experience with 4 in 1, but hope to get much of the same function with a Power Trac bucket with grapple. Although I went to Power Trac, I didn't try that system, so I don't know how the controls work. Can you recommend a source for a basic diagram or description of the lever placements for the system that you have found to be most useful, so that I can start to generate a basis for comparison - and perhaps modification?
Charlie Iliff
Charlie - First, about the grapple. When I talked with the PowerTrac folks, I asked them about a 4-in-1 bucket, but they don't build one. I was going to get a Long 4-in-1 and have them weld the attachment plate on it, which they don't have a problem with at all. They said to just have it shipped to them, and tell them how high from the bottom of the bucket it should be attached and at what angle in relation to the bottom of the bucket. This is important, because it affects the depth of dig and lift height, and the dump & rollback angles, respectively. I was just going to have it welded at the same height and angle as the stock PT bucket. But, and this is an important 'but', the reason I was going to Long for the 4-in-1 bucket is that a 4-in-1 and a grapple are entirely different animals and excel at entirely different tasks. If you're primarily interested in moving brush, logs, etc., then you may want to go with the grapple, but the 4-in-1 is a lot more versatile bucket, in my opinion. The grapple is pretty much just a regular bucket with a means of holding a load in it - this is over-simplifying it somewhat, but not by much. The 4-in-1, on the other hand, will do everything the grapple will do, though it won't hold as much brush, etc., but it will do all kinds of things a grapple won't. You can pick up loose material with it, grade in many unique and versatile ways, etc. Do a search on the archived info about 4-in-1 buckets, and you'll see what I mean. All I'm saying is, don't pick a grapple bucket because it's all PT builds, and assume it's going to be similar to a 4-in-1 - they're not.
As for the linkage question, it's very complicated to describe, at least for me. Basically, you have two joysticks. The left one acts just like a regular FEL joystick. The right one controls the 4-in-1 bucket, but there's some linkage that connects it to the left joystick. The net effect is that you can open/close, rollback/dump, and lift/lower the bucket at the same time. (Obviously, I don't mean you can open & close the bucket at the same time, but that you can do one of that pair of functions at the same time you're doing one from any, or both, of the other pairs...) It's a whole lot more complicated to design or explain than it is to use, I can tell you that. As for a place to refer you to for a diagram, I don't have a clue. I also doubt that you could put such a linkage on a machine not designed for one. All the versions I've seen were complicated enough that they were floor mounted and required more space than you would have on a loader-mounted or console mounted version. I'm not saying it couldn't be done, just that I don't know enough about them to see how it could be. I looked a little at trying to figure out how to do it on my Kubota, and decided it wasn't feasible.
MarkC
/ EarthForce EF-5 enhancements #28
Mark: Thanks. I think my main use is certainly picking up logs, brush, etc. so the grapple will generally be fine. I will be doing very little digging. A neighbor has a 4 in 1 on a John Deere 4400, and I plan to stare at and play with that a bit before spending any money. I will keep the Long bucket idea in the back of my mind. I think, however, that the Power Trac controls on the 1430, not the 24## will not likely be the best configuration for a 4 in 1. Never can tell, maybe when your machine comes in, I'll run down from Maryland and watch you do wonders with it.
Charlie Iliff
Charlie - How far are you from Baltimore? Jason @ Folcomer Equipment has an EF-4 on the lot (and a smaller one, but I'm not sure which one) that has the 4-in-1 linkage on it. It's by far best to play with it to understand how it works. I'll warn you, though: If you play with that control style a little, you won't be nearly as happy with any other arrangement. Besides, Jason's cool about just letting you kick tires - he's not struck me at all as a "sales type", although he obviously does pretty well at it, since he's the manager at that location; maybe that's his secret. Before I hooked up with him, I talked to one of the branch managers at another Folcomer location closer to home, but when I wanted to buy, I called a different branch just to get somebody else - I'm not going to buy from someone I don't like. (If you tell Jason you're there because I referred you, he'll probably be afraid you're as difficult a customer as I am, then be so pleasantly surprised that you'll get even better treatment. /w3tcompact/icons/laugh.gif)
MarkC
Rob - That water jet cutter sounds like a pretty vicious device. I think I'd like to have one of them for the tool kit in the back of the pickup. /w3tcompact/icons/laugh.gif
I talked to Jim @ D&E about the pad eyes - he calls them chain dogs - and he's going to make 6 of them for me for $20 a piece. I think that's a pretty good price, since they're 6" x 3" pieces of 3/8" T-1 plate, plasma cut with radiused corners. I spec'ed them with a 2 1/8" center hole and a 7/16" wide x 1 1/2" long slot going out in two directions from center, so the chain will lock in either direction. When I take the EF-5 by there to pick up the buckets, quick coupler, etc., I'm going to have them weld three of them to the back side of the loader quick attach plate, so I can use them for lift points, places to attach chains to hold stuff in the bucket, etc.
MarkC
/ EarthForce EF-5 enhancements #31
Mark:
My office is in Baltimore, although I live in Anne Arundel County, about 25 miles South. I haven't gone to see the Earth Force machine on the lot because I'm not really looking for that configuration -- I need lawn mower first, and because my finances are way below the Earth Force level. I don't feel comfortable asking a salesman for his time and wear on his equipment when there is no chance that I'll buy. I guess I miss a lot of fun: I don't test drive Porsches either. I may have to go by and at least look, however.
Charlie Iliff
/ EarthForce EF-5 enhancements #32
Re: EarthForce EF-3 & 4, and EF-5 enhancements
Mark:
OK, I couldn't stand it, so I went to Folcomer and looked at the Earth Force machines. They not only will demo, but they have EF-3 and I think EF-4 for rent. They seem fully as solid as you have said, and certainly a great platform for adaptation, modification, and other entertaining pursuits. Unfortunately, they wouldn't be very good for my primary purpose - finish mowing. For 5% of my requirements they would be perfect, but that doesn't begin to justify the $29,500 base price of the EF-3.
In addition to the tractors, I saw a collection of enhancements and attachments: a 72" Ammbusher, a set of forks, a couple of augers, a Brush Brute, and an adapter from skid-steer quick attach to 3-point and/or 2" trailer insert. Looks like a lot of fun as soon as your EF-5 arrives.
How goes the quest for hydraulic motor to adapt PTO machines to hydraulic. If I ever get the Power-Trac, that will be a capability I'll need.
Charlie Iliff
Charlie - I just hate it when other people get to see my stuff before I've seen it! /w3tcompact/icons/laugh.gif (Actually, I've seen all of it, except the Switch Hitch and the Brush Brute. What did you think of them, especially the Brush Brute? Jason said he was very impressed with the quality and workmanship of it.)
I'm glad you got a chance to see the EarthForce machines - they're worth seeing if only to be able to compare them to other things. What did you think of the 4-in-1 linkage? If I remember correctly, none of the machines there have the 4-in-1 bucket on them, but the controls are ready for one.
What did you think of the Ammbusher - I'm afraid it's a little flimsy. /w3tcompact/icons/laugh.gif
So, I take it you met Jason, too - otherwise you wouldn't have seen all the other stuff. What did you think of him?
Oops, I forgot to answer your question about adapting mechanical PTO drives to hydraulic. There's a hydraulics company salesman (who also happens to be the hydraulics engineer who helped me with some of the projects on my L4310HST) who's currently working on finding the best motor for what I need, but it partially depends on whether I decide to upgrade the hydraulics on the EF-5 as soon as I get it or not. I'm seriously considering getting a motor, adapting it to a PTO spline output shaft, and mounting it to the Switch Hitch so I can then use any three-point-hitch mechanical PTO powered implement with the EF-5, instead of just my tiller.
MarkC
<P ID="edit"><FONT SIZE=-1>Edited by MChalkley on 11/09/01 02:13 PM (server time).</FONT></P>
/ EarthForce EF-5 enhancements #34
Mark: I agree that the Ammbusher is a little flimsy, as is the Brush Brute. Flimsy sort of the way a typical Euclid is flimsy. I thought our old Woods rotary cutter was fairly robust until I saw the Ammbusher. The Brush Brute can probably be bent pretty easily in normal use, provided your normal use includes running starts at trees more than 8 inches in diameter.
The only problem I see you'll have is the semi tractor and low boy you'll need to transport the rig and the rest of the toys, er, tools from site to site. The typical landscape trailer would barely carry the Ammbusher, let alone the tractor.
I used your name to the salesman who intercepted me in the yard, and repeated it as I came in for a brochure. Jason fired out of his office to advise that he had a stack of your stuff and would love to show it to me. He also mentioned the Chalkley cup, but I didn't see a mounting adapter for that.
I saw the two-joystick setup for the 4 in 1 (6 in 1?) but won't be able to understand it until I work with them a while. Maybe someday.
If you get the hydraulic motor mounted on the switch hitch, I will be interested in how well it works. Somehow, however, one of my primary objectives - elimination of three-point hitches - might be compromised by such a rig.
Charlie Iliff
Charlie - I thought you might've gotten a kick out of the Ammbusher. It's approriately named, I think. I expected it to be very heavy duty, but when I actually saw it, it still surprised me.
I thought I had posted a picture of my trailer once upon a time, but I guess I didn't. I can't seem to find it, anyway. My trailer is a three-axle deck-between-the-wheels 24-footer. I had Winston build it to spec with 9,000 lb axles, using 6,000 lb springs. I went with the 9k axles because they've got 50% larger brakes than the next size down. Plus, I had them put brakes on all 3 axles. I wanted to be able to stop easily with no truck brakes at all, should the need arise.
You just reminded me of something else I have to ask D&E to cut out for me - a cup holder! 1/4" flat plate attached to the ROPS tube ought to do it...
As for the hydraulic motor, it would work equally well whether you mounted on a universal hitch adapter or directly to an implement gearbox.
MarkC
/ EarthForce EF-5 enhancements #36
<font color=blue>I thought I had posted a picture of my trailer once upon a time</font color=blue>
Did it resemble the attached photo, Mark?
/ EarthForce EF-5 enhancements #37
My head hurts reading this thread. Now I can't make up my mind if I want a lawn mower or to start my own excavating company. You really research your stuff, I'll give you that. When does it end? Is it gonna end up like this?(see attachment). Just kidding. I'm learning alot. Keep it coming.
<font color=green> MossRoad </font color=green>
Harv - Yep, dat be da shot! Your amazin'! /w3tcompact/icons/wink.gif
MarkC
/ EarthForce EF-5 enhancements #39
Harv:
That trailer won't hold half of the Chalkley Earth Force equipment. Maybe a railroad car is in the works.
Charlie Iliff
MossRoad - Why don't you get a lawn mower and start an excavation company with it. If you get a good one, it should work just fine. /w3tcompact/icons/laugh.gif
I'm glad you feel like you're learning from all this - I sure am. As I learn it (or think I've learned it), I'll post it.
MarkC
2023 MANITECH MTECH-2.0T TELESCOPIC WHEEL LOADER (A64279)
2023 MANITECH...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A59912)
2021 UTILITY VS2DX...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
UNUSED SWICT 72" BUCKET (A64280)
UNUSED SWICT 72"...
JOHN DEERE GRAIN DRILL ROW MARKERS (A64280)
JOHN DEERE GRAIN...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
