Earth Anchors
/ Earth Anchors
I'll keep the water trick in mind. My only experience with earth anchors has been the ones that are about 1.5 inches in dia. Have used them for temporary guys during Field Day. And they are hard to get into the ground here in MO. I wasn't sure how it would be to drive a 8" one.
A related question:
I want to run both coax and AC to the base of the tower underground using the grey plastic conduit. I'm looking for a good type of box to mount on the outside wall that would let me come through the wall and turn 90 degrees and go underground. I probably should not run AC and coax through the same conduit. Might be nice to have the Polyphasers in the same box too. I don't really need the AC, but thought that it would be handy to have at the base of the tower.
/ Earth Anchors #12
I'm still confused on Earth Anchors.
The concrete ones I've seen installed for a 150 ft. flare stack were so designed that the weight of the concrete was the anchor.
Drive in or screw types used to guy service rigs were always placed vertical or away from the object they support.
To me it would seem an 8 inch diameter anchor in line with the direction of strain would only provide 8 inches of soil resistance. A vertical one would provide 8in. x depth of soil resistance.
All the guy lines I've seen have alway been equiped with turnbuckles to properly tension the lines.
Egon
/ Earth Anchors #13
Egon,
While neither one will pull out under normal circumstances, the vertical one will need readjusting as it's pulled toward the center. The reason most people put in a vertical is because of ease of operation. The angled won't have that problem. As for strenght, an 8 inch anchor driven in to a depth of 7 or 8 feet will have more resistance than a 4 foot deep anchor, whether it's vertical or angeled. A properly inserted angled anchor, (talking power company installed), disturbs the soil very little sinced it's screwed in smoothly. Hard to do that by hand, especially in hardpan.
A well designed concrete anchor will probably out preforn a dirt anchor, but the cost is usually prohibitive, and if you decide to sell the property later on it can be a hinderance to the new owner.
Hmmm, I've probably been more confusing than helpful here. /w3tcompact/icons/laugh.gif Someplace in my junk, I have a book with drawings and formulas and stuff concerning towers and anchors. I'll see if I can dig it up.
/ Earth Anchors #14
Gary, OK I have wondered about these trams. My question is, when you put the antenna on the tram, what keeps the antenna from hitting the guys on the way up or down? I have never understood this? I like the idea, but if it doesn't work, what's the point?
/ Earth Anchors
Phalynx,
OK, here's the short story.
There are two types of tram sold by Glen Martin.
The first is made to wrap around the triangular tower and actually rides on the tower legs. With this type you can only have guys at the top of the tower because there is no way that the tram's frame, wrapped around the tower, could pass over the guy attachment points on the tower. This is marketed as the "Hazer".
The second type has a set of rails attached to only one face of the tower. These rails are "T" shaped and the tram rides on sets of rollers with the stem of the T captured between the rollers. This system allows several sets of guys at different levels.
Here's the tricky part.
When you lower an antenna with a boom, the boom will not pass the guys. But if you loosen the two guys on the side with the rails and allow them to droop down along the tower edge the mast can pass by. Then when the antenna is clear, reattach the guys and finish lowering the tram to ground level. If there is a second, or third set of guys, the process is repeated as required. If you have only a small antenna such as a 2M beam the boom could be short enough to pass by the guys..
Of course you can't do this in a high wind!
I have my setup planned so that the guy that doesn't need to be loosened is on the prevailing wind side. That's West around here.
/ Earth Anchors #16
Wow, that sounds almost scary... I would imagine that it should be horrible with no wind like you said. It does sound like a lot of work too, but climbing the tower is not what I would like either..... 250 lbs on a tower is a scary thought.....
Please post pictures of it when you are done. I am one person who is interested in seeing this as I am sure there are others.
Phalynx (KD5ILS) -- Scott
/ Earth Anchors #18
/w3tcompact/icons/laugh.gif Egon, tent pegs are ok vertical, or preferably at a 45 degree angle away. Unless you're using a screw type of peg. As you might have noticed, us hams do some weird things at times. Like climbing a 100 foot tower. A scary climb, but the view is awesome.
/ Earth Anchors #19
Egon,
Auger style anchors: If I remember correctly, an auger when pulled upon will exert its force outward from the auger at a 45 degree angle. The diameter of the auger has to be large enough so that it actually drills into the soil. Imagine the auger creating a pulling area that looks like a cone where the screw part would be the apex of the cone. Therefore, an 8' auger would create a cone with a volume of 536 cubic feet. This means you would have to have something strong enough to lift 536 cu feet or 20 cubic yards of dirt. Maybe a structural engineer reading the post can validate this information...
Joe R.
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2018 John Deere Z997R (A53317)
2018 John Deere...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
