EA Wicked Grapple Carnage!
/ EA Wicked Grapple Carnage! #61
I'm eager to see the "improved" part. The original didn't look bad.
/ EA Wicked Grapple Carnage! #62
The model T was the best car Ford ever made. Almost ran them out business with not needing replaced. They learned well after that.
Good one Murph. :)
/ EA Wicked Grapple Carnage! #63
Didn't look bad in the failed pic or the Pre-failed pic??
/ EA Wicked Grapple Carnage! #64
Thumbs up for EA, but as to ovrszd input, (not criticism) I agree. Equipment/attachments of this nature will always be abused or pushed to it's limits, and should be designed 40-50% beyond "rating". It appears to me also that there was clearly room for improvment on that cyl. mount. Attachment weight becomes more important as the carrier gets smaller, but another 2 pounds of steel on those mounts is irrelevant.
Again, it's refreshing to so a company "stand up". They are clearly in it for the long game.
Well I'm not the best at stopping to take pics, but I have the lids both done. Can't see me ever needing to address these again. The replacements are stout. I need to use the grapple to clean up a neighbors downed oak tree so I might wait to do the rear since they will take a little longer. Total time was prolly 1.5 hrs so far but I was taking my time
Brett
Tractor had to go to the shop because it's always something. Most recently it will only go 10mph in road gear. C2. Anything higher and it looses all power and can't hold. Also won't throttle up higher than 2300. Pto is 2500.
Kids are still waiting to be installed. Don't know when I'll be able to put the rear brackets on. Lid bracket was very straight forward.
Brett
/ EA Wicked Grapple Carnage! #67
Brett
I hope it's something simple, Brett - like water in the fuel filter partially obstructing fuel flow (I ran into that a year or so ago).
I hope so. I'm sick of dealing with headaches. They had to split the tractor at 100 hrs due to a internal leak it came with. It's always something. Every once in a while I'll go about 45 mins without any sounds or alerts and I get so excited.
Brett
/ EA Wicked Grapple Carnage! #69
That's too bad, no one should have to deal with that on a new machine, regardless of brand. Good luck, hopefully it gets more reliable for you.
Hoping to get my tractor back in the morning. They are blaming contaminated fuel and a plugged filter for the intermittent power loss. Funny thing is I fill it only off my slip tank in the bed that also has a filter and water separator. It also fills my truck which I have never had an issue with. So then he switched gears and asked if I kept it outside. (Like all the tractors on their lot are) I said yes. He said it could be from all the rain so I inquired if they checked the fuel cap which is perfect. He told me he would check with his guys and repair if needed. I'm going up there and will probably loose my mind if they continue down this path.
Brett
/ EA Wicked Grapple Carnage! #71
Sounds like bs. Ask them for a copy of the fuel analysis. If they didn't drain the tank then take your own sample in case they want to push it.
Apparently, the shop manager wasn't on the same page as the foreman. It seems the throttle bracket was weak and not allowing it to fuel fully. The filter was dirty but the fuel was clean. Screens were good but they checked that and also replaced all the line. Went to load it on the trailer and it didn't register anything on the fuel gauge. Took it in with 1/2 tank, maybe more. Asked if they unhooked the sending unit or they were giving me a tractor back that was bone dry. They checked the wiring and then the fuel level. Yup, bone dry and they added 10 gallons. Got the tractor home and hooked up the box blade. Now the 3pt won't lift. I hate this tractor. They are sending a guy out Monday to adjust the linkage.
Getting real tired of the crap
Brett
/ EA Wicked Grapple Carnage! #73
Sounds like either your dealer or the tractor is a lemon (or most likely a combination). For me it would be time to trade for a new dealer and manufacturer even with the financial loss.
I feel for you bud.
/ EA Wicked Grapple Carnage! #74
Sorry you are having these problems. Hope you get resolution soon..... :(
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A65643)
2012 INTERNATIONAL...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
Jitter Bug (A62613)
Jitter Bug (A62613)
