DXF file
/ DXF file #2
That's autocad's interchange format. Lot's of programs can load and view then, and a number can edit them too. A good drawing package like Adobe Illustrator or Photoshop will work. Perhaps corel draw too. Visio maybe?
/ DXF file #3
Dave,
I found a handy little site to found out what programs open which file extensions. You need Autocad to open DXF files.
http://extsearch.com
I hope that helps.
Kent
/ DXF file #4
If you just want to view the file (and print as well), you can download a free (AutoCAD) viewer from <A target="_blank" HREF=http://usa.autodesk.com/adsk/section/0,,837637-123112,00.html>here</A>
/ DXF file
Thanks guys!
I downloaded that Volo program.
24 Meg!! /w3tcompact/icons/shocked.gif
Turns out that the bed plans I downloaded
sucked! What good are plans that show the pieces
but don't give dimensions?
Any way, any one got a good site that has plans
for a bed? I'll be using some white ash that was cut from the wood lot. It's from my son who's three now.
/ DXF file #6
<A target="_blank" HREF=http://www.rockler.com/ecom7/findprod.cfm?&DID=6&sku=5013>Rockler</A> has some bed plans in their catalog. The one I linked is for two twin beds that convert to bunk or loft/twin beds. You could build one now - and be prepared for the future! I've never ordered plans from them, but everything else I've ordered in the past has been top-notch and "as-advertised".
/ DXF file #7
The dimensions may have been on another layer that is turned "off". If you could have someone with ACAD look at the drawing, they could tell you.
ACAD has different layers that make it handy to have drawings that you can select only those parts you want to see.
Also, if the dimensions are missing, it wouldn't be difficult to add them in ACAD if the drawing file were opened in ACAD rather than the viewing-only program........................chim
/ DXF file #8
"ACAD has different layers that make it handy to have drawings that you can select only those parts you want to see.
Also, if the dimensions are missing, it wouldn't be difficult to add them in ACAD if the drawing file were opened in ACAD rather than the viewing-only program"
Very true, Chim...but then you're looking at spending money. AutoCAD goes for a few thousand bucks now.
Of course, you can get AutoCAD Lite for less then a thou....or try eBay for an older version. There is also IntelliCAD which open .dwg and .dxf files.
/ DXF file #9
What's the source for the plans you downloaded? I'll take a shot at getting the dimensions.......................chim
/ DXF file #10
DeltaCad will open and work dxf files. It is a simple but very good AutoCad style program. My Plasma Cam cutter will cut off of dxf files directly so I use these a lot. It is a 39.95 program also a 30 day free trial <A target="_blank" HREF=http://deltacad.com/>http://deltacad.com/</A>
/ DXF file #11
The October issue of Wood magazine has an article on "kid-friendly beds". You can build them as bunks or twins. There is also an article on a matching dresser. The articles include plans, material lists and detailed instructions. I just got my copy in the mail this week - I'm not sure if it is on the stands or not.
-david
2020 DRAGON ESP 150BBL ALUMINUM (A67714)
2020 DRAGON ESP...
2015 Freightliner M2 106 Hawk H-1150TL Forestry Grapple Truck (A66736)
2015 Freightliner...
2000 Hino (A64194)
2000 Hino (A64194)
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2004 Johnson 70hp 4-stroke Outboard Boat Motor (A66738)
2004 Johnson 70hp...
2017 TAKEUCHI TL8 SKID STEER (A65056)
2017 TAKEUCHI TL8...
