dwdave
/ dwdave #1
dwdave
TC35D No Hydraulics
I hope someone can help my NH lost all hydraulics to the FEL and 3 pt. Everything else still functions properly. (HST,pto, etc.) This is my first post so if I have broken any rules please forgive me
/ dwdave #2
Welcome to TBN... other then posting a New Holland question in a JD forum :eek: I think you did fine with your first post!! Hopefully, a Moderator can move your question but I'll give it a shot... There is a knob, most likely under your seat, that controls the 3 point hitch. Any chance that the knob was shut off? How old is the tractor? and when was it serviced last? That information might help...
/ dwdave #3
One of your quick connectors has come disconnected. Check all of them and they can be disconnected and not look like it.
/ dwdave
Thanks for the feed back. Believe it or not I'm still nervouse about posting on here (First time posting anywhere in my life which explains the error in posting in JD section) The NH uses the same hydraulic system for the FEL and 3pt. The hoses are all connected I removed and reattatched to make sure. They just went dead while using the rear mower. The tractor has 320 Hrs on it and had all fluids changed last year . (290 Hrs ) thanks for your help.
/ dwdave #5
At this point, with noone reading the thread called "dwdave" in the JD section, I would NOT respond to this post anymore but rather start a new post in the New Holland section and use a more informative subject line... which most people look at and will "catch" someone's eye. Something like "Help with TC35D No Hydraulics" Make sure to repost the fact that you tried what was listed here.
It seems that the tractor has few hours, any chance that it's covered under a warranty from a dealer? or did you buy this used?
2014 Keystone Passport 3220BH (A62613)
2014 Keystone...
2015 New Holland 560 Round Baler (A63688)
2015 New Holland...
2016 Deere 550K (A64126)
2016 Deere 550K...
QA Sweeper (A64126)
QA Sweeper (A64126)
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2023 Case TV380 (A62177)
2023 Case TV380...
