Dumpster diving finds - let's see yours
   / Dumpster diving finds - let's see yours #71
Pulled a box full of Delta Drive belts, jig saw blades, and two packs of sanding disks all new still in their boxes.
   / Dumpster diving finds - let's see yours #72
A Garmin GPS unit with lifetime map updates! It was complete with traffic cord and mount. Found alongside an Echo CS-400 chainsaw. Started on second pull! I too have been warned about bringing more home than I take!
   / Dumpster diving finds - let's see yours #73
My boss was always wanting to oven dry samples and apply a moisture correction when we took nukes. I hated it what’s the point of the nuke gauge if you don’t get instant results.
Maybe it's Dollar General, or Walmart, but one of the big chain stores QC still (as of 2 or 3 years ago) required the old slide hammer cylinder sample, and speedy for moisture, and scaling ,and all that BS. I've seen it once or twice. I mean, I guess you have a fixed volume, you weigh it, subtract the accurate moisture %, and it's nothing but math to get a dry PCF... but as long as the nuke gauge guy doesn't test pumping material, they are accurate and fast.
   / Dumpster diving finds - let's see yours #74
I think the slide hammer is called a Drop Cone Pentrometer. I’ve done that more recently.
The Speedy was used in conjunction with a sand cone. You’d dig a small hole and weigh the dirt that came out. Then with a device that dumped sand in that hole you could weigh how much sand went in the hole. Then with a sand of known density the volume of the hole could be computed and Speedy would figure the moisture you’d get a pound per cubic foot answer. Then with last time I did that was about 1986 and it was for a Walmart.
   / Dumpster diving finds - let's see yours #75
I dont think the Craigslist app even works anymore.
They must be getting killed by Facebook. Does anyone even use Craigslist any more?
   / Dumpster diving finds - let's see yours #76
   / Dumpster diving finds - let's see yours #77
I stopped using Craigslist because it seemed like everybody else there was either a dealer or a scammer.
   / Dumpster diving finds - let's see yours #78
Same here. I'd had enough of kids playing games.
   / Dumpster diving finds - let's see yours #79
We have a dumpster site about 4 miles from home we use once a week. About a year ago there was a large antique hump back chest below a dumpster with the attendant lady standing there. She said it was too heavy to lift it up and in. She said a middle aged guy left it for trash and it belonged to his recently deceased father.
We looked inside and it was packed FULL of (drum roll...) baseball cards!!!!! All organized, many of them autographed, many in plastic with a rating seal. From what I could see a wide variety of years, some were very old.
Unfortunately we were in a car and in a hurry. If in my truck I would have loaded it and I'm not a collector.
The lady working there said she would call a collector she knew. To this day I think about I should have gone home, got the truck. Who knows what it was worth...thousands of cards.
   / Dumpster diving finds - let's see yours #80
That hurts, I remember When I was 10'ish my dad and grandfather would take me out to a line of dumpsters, the local mines were auctioning off huge amounts of tools, and what ever was not sold was pitched, we helped alleviate their loads. (Allegedly)
Giyi Mini Land Leveler (A53316)
Giyi Mini Land...
New/Unused CFG Industrial QH12R Mini Excavator (A54865)
New/Unused CFG...
2005 Gravely 260Z 60in Zero Turn Commercial Mower (A55787)
2005 Gravely 260Z...
Giyi Pallet Forks (A53316)
Giyi Pallet Forks...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
