Dumping Trailer for Towing B2320DT
/ Dumping Trailer for Towing B2320DT #1
mswlogo
NH, USA
Kubota B2320 DT (Gear)
I plan to buy a Dumping Trailer.
Like one of these: Dumping Trailers
I thought perhaps if I got one big enough it could also be used to Tow B2320DT around.
I rarely have to tow it. But since I'm getting the Trailer any way, why not spec it for towing B2320 too.
How would Ramps work (with a dumping trailer)? The back of dump trailer has a swinging gate normally.
I was planning on getting a small one. What's the absolute minimum size I could get away with?
I don't care if it's inconvenience to say sit bucket over the end etc. Since it's not that common I will tow with it.
B2320 isn't all that heavy. It does have an L304 Loader on it. And usually a light duty 48" box blade.
/ Dumping Trailer for Towing B2320DT #2
One question that I'd have is can you secure the tractor to the trailer - are there any tie-down hard points?
/ Dumping Trailer for Towing B2320DT #3
I have a dump trailer with the barn doors and ramps. It works fine. the dump body has welded in D-rings for tie down points. You just need to measure how long your tractor is with loader and box blade to know what length trailer to get.
Nice !!!! I love it. I want !!
What brand is that?
The barn doors are awesome. I wondered how that would get resolved duh.
/ Dumping Trailer for Towing B2320DT #5
What brand is that?
My trailer was built by Cross Country Mfg. here in NY. It's 16' x 80" wide. Has 6 D-rings welded in for tie downs. Barn doors with ramps. Load cap. is 10K. Once the doors are open the ramps have a lip to sit on. Here;s a few more shots.
I'm drooling.
Is it easy to remove ramps for dumping? Oh wait I just noticed the ramps tuck under.
2007 Freightliner B2 School Bus (A61573)
2007 Freightliner...
213154 (A64276)
213154 (A64276)
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
2009 Ford E-350 Cargo Van (A61573)
2009 Ford E-350...
JLG HC3 8ft Boom Lift Man Basket Attachment (A61572)
JLG HC3 8ft Boom...
2020 Freightliner M2 106 Altec LR7-56 56ft Forestry Chipper Insulated Bucket Truck (A61573)
2020 Freightliner...
