Dump truck tarp arms L bend
   / Dump truck tarp arms L bend #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
When looking at Dump truck tarp systems, a lot of them (most that I see) have the arm on the side in the shape of an L instead of just straight.
I am sure there is an advantage to this design, I just do not see what it would be. I was thinking it would be a height thing but that does not seem right.
Thanks for the insights.
   / Dump truck tarp arms L bend #2
Alan,
I think it has to do with the hydraulic cylinder that pushes and pulls the cover open/closed. With the "L" design, the cylinder can be shorter and have more leverage to unroll the tarp against the spring tension.
If you draw the two (straight and "L) designs on paper in the open and closed positions I think you will see what I am talking about.
   / Dump truck tarp arms L bend #3
Actually the L bend positions the arm down below the side of the truck so it won't be damaged when loading from the side. I have loaded trucks both ways and it is much easier to load the L bent ones.
Case-IH 160 Puma (A50120)
Case-IH 160 Puma...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2013 John Deere 824K (A52748)
2013 John Deere...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
