Dump truck tarp arms L bend
   / Dump truck tarp arms L bend #1
AlanB
Elite Member
Clarksville, TN, USA
NH 1925
When looking at Dump truck tarp systems, a lot of them (most that I see) have the arm on the side in the shape of an L instead of just straight.
I am sure there is an advantage to this design, I just do not see what it would be. I was thinking it would be a height thing but that does not seem right.
Thanks for the insights.
   / Dump truck tarp arms L bend #2
Alan,
I think it has to do with the hydraulic cylinder that pushes and pulls the cover open/closed. With the "L" design, the cylinder can be shorter and have more leverage to unroll the tarp against the spring tension.
If you draw the two (straight and "L) designs on paper in the open and closed positions I think you will see what I am talking about.
   / Dump truck tarp arms L bend #3
Actually the L bend positions the arm down below the side of the truck so it won't be damaged when loading from the side. I have loaded trucks both ways and it is much easier to load the L bent ones.
CAT 973 (A47384)
CAT 973 (A47384)
2004 PETERBILT 385 (A52472)
2004 PETERBILT 385...
MANLIFT (A52472)
MANLIFT (A52472)
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
CATERPILLAR IT28G (A52472)
CATERPILLAR IT28G...
Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
Godwin CD150M 6in...
