dump trailer modifications?
/ dump trailer modifications? #1
kiotibill
Center County , PA
Kioti CK20s HST
I recently purchased a dump trailer for use around the home/barn. It is a Maxum 5 x 8 Low Profile Dump Trailer (5,000 lb GVWR). It has been fine but in use I have noticed something I may have overlooked when shopping for the trailer. It has power up and gravity down. Once lifted up with a load, I cannot let it down unless I dump all of the material in the bed because the weight makes it come down VERY fast! :eek: Is there a valve that could be installed that would let me vary the speed at which the bed comes down under weight so that everything in the bed doesn't have to be dumped to let the bed back down?
/ dump trailer modifications? #2
A one way restriction needle valve would do it....
Another possiblility is to limit the spool stroke on the controlvalve so the dump will be "throttled" down....
Is it a manual or electric control valve???
/ dump trailer modifications? #4
You are vague on the type of hydraulic system it is.
Is it off tractor or power pack?
most power packs have a built in flow control in the solenoid tha tyou can adjust.
off tractor you might have to add flow control.
pictures are worth 1000 words and eliminate a lot of questions.
tom
/ dump trailer modifications? #5
I would recommend this valve, allows 7 GPM in one direction, and 3 GPM in the other direction. Only $8
A needle valve will restrict, but in both directions.
https://www.surpluscenter.com/item.asp?UID=2228012112543145&item=9-1207&catname=hydraulic
/ dump trailer modifications? #6
/ dump trailer modifications? #7
tom
Good post tommu56!!;)
/ dump trailer modifications? #8
Adjustable would be better since the weight varies...didn't you argue with others before about suggesting the use of fixed restrictors?
The poster never did say the gpm flow rate, but he did said he wanted it to lower slower. Not restrict in both directions. This setup will do just about what he wants, I believe. 7 gpm rate is a good lifting speed, and half of that would work for the drop rate. I don't see a problem.
The needle valve will also work in both directions. Adjust the flow for whatever.
/ dump trailer modifications? #9
NOT the one I linked, Read the description:
New PARKER. All steel valve with "Colorflow" color band for easy flow adjustments.
F SERIES Adjustable flow control valve provides precise control of oil flow and shut-off in one direction and full flow the opposite direction.
/ dump trailer modifications? #10
kennyd ,
You are correct, I did not read far enough. The one I suggested is a less expensive alternative.
/ dump trailer modifications? #11
hi guys... what if you parallel install a velocity fuse in conjunction with an orifice to control the speed, the oil flow when the dump is empty will flow through the velocity fuse but if the extra weight in the dump causes the speed to increase it will cause the velocity fuse to close causing the oil to go through the orifice valve there for controlling the lowering speed??? Jim HYDAC USA : Hose Break Valves/Velocity Fuses
/ dump trailer modifications? #12
I am using a dump trailer but with tractor. Since the tractor has remote hyd with more capacity and more convenience to it's controls than the trailer's set it to plug in to tractor. If that is your set up you should be able to control the drop by the lever movement easy.
I guess I didn't mention that the hydraulics are completely self contained - 12 V electric runs the hydro pump. Choose that so that I can use it with truck (on the road) also with no modifications. I will try and get some pictures to post, but it might be a few days. would be nice to vary the speed down since I'm sure different loads would need different settings. Thanks, eveyone - I'll check out some of your suggestions in the meantime.:)
/ dump trailer modifications? #14
If you use it with your tractor a lot and your tractor has remote hyd I think you will be surprised how much quicker and all you can do so from the tractor seat. If you care to do so and still use the current set up you will need to install some quick disconnects and probably a set of hoses to run from pump area to tractor.
For my use it was really worth it. We were dumping a load at least once every 10 minutes and the switch I know saved 30 to 60 seconds per load and was safer as holding a button was not required. If you are only running a load once in a while stay with your set up.
/ dump trailer modifications? #15
A velocity fuse would be a good idea to stop flow from exiting the cylinder in case of a hose break which is what theyre typically used for. For this application however I would use a pressure compensated flow control with reverse free flow sized appropriately for the line. A pressure compensated flow control as opposed to a plain needle valve will compensate for pressure variations in the line while keeping the flow rate relatively constant which means that your dump trailer will come down at the same speed every time and because of the reverse free flow check you will not impede flow into the cylinder to raise the load. A velocity fuse will slam shut causing a huge pressure spike and potentially blow up a hose, its used right at the output of the cylinder to eliminate downstream spikes and is an emergency use valve.
I would go with this valve because I like the manfacturer but you could use any other brand you like or have available. go with steel not brass.
http://www.dmic.com/wp-content/uploads/PC1H_low.pdf
install it RIGHT AT the inlet of the cylinder or as close to it as you can, that way if a line breaks you will have an automatically controlled descent.
Sellick S80 (A60462)
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
159116 (A60430)
159116 (A60430)
2010 Chevrolet HHR SUV (A61574)
2010 Chevrolet HHR...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
2019 CAT 330GC EXCAVATOR (A63569)
2019 CAT 330GC...
