Dump-Pro Dump box
/ Dump-Pro Dump box #1
BigEddy
Eastern Ontario
JD 855, 322, AMT626 plus whatever my son dragged home this month
Caught an ad for these in Compact Equipment. Looks pretty slick to me - not sure how much they are yet, but if I can retain all my limbs, I could be persuaded.
Dump-Pro
Anyone have any feedback?
Thanks
Big Eddy
/ Dump-Pro Dump box #2
And it even holds water!!! LOL.....Good luck going very far without getting soaked.
Seriously though it would be handy. There have been plenty of times something like that could have been put to use.
/ Dump-Pro Dump box #3
I have the EZ-dumper, made out of steel, works great and I take in in and out of my truck with my tractor, takes about a half hour including bolting it down and hooking up the 12 volts. I like the non-rusting concept, but wonder it it will hold up to hauling stone. The EZ-dumper uses a hydraulic pump and cylinder instead of a winch.
/ Dump-Pro Dump box #4
The Dump-Pro looks pretty neat. Anybody know what they cost?
/ Dump-Pro Dump box #5
Oh about $1,900. /forums/images/graemlins/smirk.gif
Lar
/ Dump-Pro Dump box #6
3 months..................................
Thats how long I think it will be before someone here builds one just like it using scrap.
/ Dump-Pro Dump box #7
Doesn't have all the functionality, can't move fluids, but this is a cheap alternative:
Loadhandler Anyone out there used one?
Larry
/ Dump-Pro Dump box #8
<font color="blue"> Loadhandler Anyone out there used one? </font>
Lots of threads on this. Did a Search and here's a link to one of them.
/ Dump-Pro Dump box #9
The loadhandler doesnt work as well as the dump-pro. I had a loadhandler and had a load of gravel and could barely get it out, just imagine a thousand pounds of gravel and basically a tarp to roll it out.
/ Dump-Pro Dump box #10
</font><font color="blue" class="small">( And it even holds water)</font>
I watched a site being dewatered with dump trucks, once. They couldn't lay a discharge line across a busy street, so they pumped the water into dump trucks with rock bodies (no tailgate), trucked it across the street, and dumped it into the river.
I suspect it was expensive and they didn't have to go far.
/ Dump-Pro Dump box #11
Yep I have a loadhandler, works great, have dumped 1800 lbs. of 3/4 stone no problem, drove down the driveway and dropped as we went. But, had a load of asphalt shingles went to the dump and they got caught up behind the wheel wells and had to hand unload. They make an add-on mat for your bed to decrease friction (easier to unload) only drawback is once you start to unload you cant stop and close tailgate. /forums/images/graemlins/ooo.gif
/ Dump-Pro Dump box #12
</font><font color="blue" class="small">( ...they got caught up behind the wheel wells and had to hand unload. )</font>
That is what I was worried about when looking at one. If you fill the box there will be a ton of stuff sitting in front/back of the wheel wells.
/ Dump-Pro Dump box #13
CTyler its made for a pickup truck, not a 10 ton dumptruck ( what in the world do you fill your bed with???) /forums/images/graemlins/grin.gif, you can easily make some plywood "wings" to block stuff from filling the between the cab and the wheel wells and it doesn't matter between the wells and the tailgate
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
2003 TEREX  60 TON CRANE (INOPERABLE) (A67714)
2003 TEREX 60 TON...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2013 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2013 ALLMAND...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
