DUMMY, DUMMY, DUMMY
/ DUMMY, DUMMY, DUMMY #101
I had a friend tell me a story of him and his friend roofing a house. His friend, a professional roofer, was running backwards unrolling the tarpaper while my friend chased him with the staple gun, stapling the paper to the roof deck. My friend looked up just in time to see his friend run backwards right of the roof, land on both feet and looking back at him wondering what in the heck just happened !?!
/ DUMMY, DUMMY, DUMMY #102
The one that sticks in my mind the most was last summer I bought a used Round Baler. It didn't have a PTO shaft so I borrowed one off my Brush Hog. Unfortunately it was too long, so I cut 6" off of it. I figured heck, I'll just get a new one for the BH.
Then one day, as I was adjusting the draw bar out to the next length setting my wifey says to me "Gee, I wonder if the shaft woulda fit if you had moved that thingey then?" /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif
Well Duh!
/ DUMMY, DUMMY, DUMMY #103
About 25 years ago my Dad and I owned a Plymouth Volarie (sp?) stationwagon. The spare was stored under a false floor in the back. Being a hatchback, it would leak water into the subfloor and fill up around the spare.
We decided to drill a couple of drain holes so that the water would not collect and rust out the subfloor. A couple of 1/4" holes and the water drained quickly underneath the car.
One small problem, when I looked under the car, it was dry!! My Dad and I managed to drill right into the gas tank!! /forums/images/graemlins/blush.gif
We still laugh about that 25+ yrs later! /forums/images/graemlins/grin.gif
/ DUMMY, DUMMY, DUMMY #104
Ever get a new truck that sits up higher than the old one and forget about that fact when you get out.I saw that done last night
/ DUMMY, DUMMY, DUMMY #105
Keep the Stroies comming I just love them
DougM
/forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
/ DUMMY, DUMMY, DUMMY #106
I know a guy that showed up for work one day a little early and the gate was locked no big deal. He waited 30 mins before they said on the radio it was Saturday
/ DUMMY, DUMMY, DUMMY #107
Got home last night and the kids told me to go check something out back. Seems some guy was moving snow recently and caught the top of my retaining wall with the bucket. Pushed down a small section. I guess I'll have to clean up after the guy today. Maybe I'll post some pictures when it gets lighter out. Sad thing is, this guy used my tractor to do the damage /forums/images/graemlins/smile.gif
/ DUMMY, DUMMY, DUMMY #108
The guy I had run the gas line to the garage to be hooked up at a later date had a little bit of a whoops this weekend while he was digging the trench for it. Seems the rear blade got a little too close to the propane tank. Moved the tank 4 or 5 inches, but a least it stayed on the blocks and didn't explode /forums/images/graemlins/grin.gif /forums/images/graemlins/shocked.gif. I won't do anything about it though as the line was being put in so that when we swap the tank out here in the next couple of weeks I can "T" into for the garage and not have to shut the gas off for a second time. Could you tell it was the first time the guy had used his new-used blade on the tractor? Wouldn't think a little NH could move that big (500 gal) tank would ya? /forums/images/graemlins/laugh.gif
/ DUMMY, DUMMY, DUMMY #109
</font><font color="blue" class="small">( Wouldn't think a little NH could move that big (500 gal) tank would ya? )</font>
I would sure think it would move 500# tank and more. I know my little Kioti will and the NH is certainly strong too. John
/ DUMMY, DUMMY, DUMMY #110
I guess I was surprised at how easy it moved it. Considering I just barely bumped it, was barely moving, and the F450 hoist truck they just to set it was tossled around pretty - yet I know it was a swing pendulum on that hoist and sticking out there so if formed a lever. Still wouldn't thought it would've moved that easy.
/ DUMMY, DUMMY, DUMMY #111
well all you gotta do is drill a hole in the bottom of the tank. the water will drain out and the lighter gas will stay on top /forums/images/graemlins/laugh.gif
I'm full of great ideas!
/ DUMMY, DUMMY, DUMMY #113
When rototilling the lawn you have to remind the tractor operator that most tractors can't turn 90 degrees, esp. important when working around the brand new landscape timbers you just built a flower bed with...4X4 pressure treated wood is no match for rototiller tines...see pic.
Andrew
/ DUMMY, DUMMY, DUMMY #114
I thought that's what landscape timbers were supposed to look like!! Mine do.
Bill
/ DUMMY, DUMMY, DUMMY #115
</font><font color="blue" class="small">( . . .4X4 pressure treated wood is no match for rototiller tines...see pic.)</font>
Andrew, thanks. You've solved my woodchipper problem. I'll just get a rototiller.
Cliff
/ DUMMY, DUMMY, DUMMY #116
The wife & Me put new siding on the barn.then one of us ran the forks through the side of the building.The one with 38 years as operating engineer.I felt bad for the wife.
/ DUMMY, DUMMY, DUMMY #117
yep SOME DUMMY hit a 500 gal tank full with the FEL while mowing this summer too, it moveed very quickly too! /forums/images/graemlins/blush.gif don't ask how <h1> I </h1> know. it also will scrape off a big hunk of paint to boot! /forums/images/graemlins/crazy.gif
I had to fix it & actually lifted it with said FEL slightly to move it back onto the blocks center, the bump was just a glanceing blow luckly!! /forums/images/graemlins/wink.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
mark m (err erase that tag line and any ack knolagement of the for mentioned occurance! /forums/images/graemlins/wink.gif
/ DUMMY, DUMMY, DUMMY #118
That sure sounds familiar. I was skidding logs out one fine day last fall.
Had the chainsaw in the bucket, rolled the bucket over to hook up the chain( hooks are mounted on top of the bucket)
ran over a big "rock" I did not see. Low and behold someone must have thrown my chainsaw under the wheels of my tractor. Boy that sure did slow up progress that day.
/ DUMMY, DUMMY, DUMMY #119
</font><font color="blue" class="small">( 4X4 pressure treated wood is no match for rototiller tines. )</font>
Neither is asphalt. As I, I mean a friend of mine, found out the hard way.
/ DUMMY, DUMMY, DUMMY #120
A dummy I know got his tire chain caught in his snowblower, man was he cussin'
Bill
ARIZONA DRIP SYSTEMS-SUNDANCE TAPE INJECTOR (A64280)
ARIZONA DRIP...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
UNUSED WOLVERINE TDB-11-78W-78' BUCKET (A64281)
UNUSED WOLVERINE...
KUBOTA 72" PIN ON BUCKET (A64280)
KUBOTA 72" PIN ON...
AGROTEC ASE1054 TOWABLE SPRAYER (A64280)
AGROTEC ASE1054...
