dumb question - BX22 hydraulic lever
   / dumb question - BX22 hydraulic lever #11
longway5:
Don't worry you can't burn out your pump. the pressure will limit at the relief setting. The fulid will heat quickly in the transmission and could eventually damage seals due to overheating, but you would smell it.
paul
longway5
Thanks for the response...it puts my mind at ease. Judging from your profile, it appears you know what you're talking about. TBN is great.
   / dumb question - BX22 hydraulic lever #13
I guess my reply from yesterday didn't make it online, but I was mistaken about burning out the hydraulic pump. I talked to our mechanic yesterday, and he said basically the same thing as Techman. Leaving the lever in the up position will cause the system to divert the fluid through the relief. All that fluid going through the relief will add heat to the system, and it's the heat that could eventually cause damage.
As for me knowing what I'm talking about, there are a lot of people who know a lot more than I do, but thanks for the complement.
Thanks for the follow up longway5, I do appreciate the info. Sorry to burst your bubble, but the complement was meant for Techman.
2016 Ford F-150 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
NEW HOLLAND TS115A TRACTOR (A58375)
NEW HOLLAND TS115A...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
