dumb question - BX22 hydraulic lever
   / dumb question - BX22 hydraulic lever #11
longway5:
Don't worry you can't burn out your pump. the pressure will limit at the relief setting. The fulid will heat quickly in the transmission and could eventually damage seals due to overheating, but you would smell it.
paul
longway5
Thanks for the response...it puts my mind at ease. Judging from your profile, it appears you know what you're talking about. TBN is great.
   / dumb question - BX22 hydraulic lever #13
I guess my reply from yesterday didn't make it online, but I was mistaken about burning out the hydraulic pump. I talked to our mechanic yesterday, and he said basically the same thing as Techman. Leaving the lever in the up position will cause the system to divert the fluid through the relief. All that fluid going through the relief will add heat to the system, and it's the heat that could eventually cause damage.
As for me knowing what I'm talking about, there are a lot of people who know a lot more than I do, but thanks for the complement.
Thanks for the follow up longway5, I do appreciate the info. Sorry to burst your bubble, but the complement was meant for Techman.
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56435)
2023 Kubota...
JOHNSON 6HP OUTBOARD MOTOR & STAND (A58374)
JOHNSON 6HP...
1408 (A57192)
1408 (A57192)
JOHN DEERE 630 DISC HARROW (A52708)
JOHN DEERE 630...
JOHN DEERE HAY CUTTER (A58214)
JOHN DEERE HAY...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
