(Dumb) filter question
   / (Dumb) filter question #1
Will
Athens, Georgia
B2410HSD
How many hydraulic filters are there on a Kubota B2410HSD? I was expecting 1, like on my B2100, but when I took a look at the other side of the tractor, there seems to be another one. Rereading the manual seems to confirm that that there is a filter on both sides.Just HYPOTHETICALLY suppose someone was dumb enough to replace only one filter and then fill the hyrdraulics with about 3 gallons of expensive Super UDT fluid. Would there be any problem draining the fluid into a clean container, replacing the other filter, and putting the fluid back in afterwards?Thanks,Will
   / (Dumb) filter question #2
Will,
I just did that on my 2910. Got a clean 5 gal bucket ran tractor on one side ramp, place bucket remove filter and catch the good stuff. Had a screened funnel to put back in after correct filter was inplace.
I've only put 7 hrs since but everything seems to be fine.
Good luck.
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
