Dual Dozer
/ Dual Dozer #2
I priced one out years ago....thats why I don't have one ;) Looks like a great idea but it would have to be used almost everyday to justify the price imho...
/ Dual Dozer
I ran across this one slightly used for about 1/3 of new so I bought it.
It has adapters for a cat-1 TPH and a skid steer quick-attach.
I'm currently in the process of hooking it up to my machines.
Looks like it will make my box scraper obsolete. :D
/ Dual Dozer #5
I just finished adding a quick disconnect plate on the back of my box scraper. My intentions are for grading & leveling with the skidsteer and pushing mulch into piles with the tractor. Still has the 3 point links for normal usage.
/ Dual Dozer
/ Dual Dozer #9
We had a guy come and finish a job for us using the same setup with a box blade on a tractor. It was pretty slick for finishing a building pad. If you are going to do any other flat work with a slope I'd recommend having a dual plane laser. You can then work a slope going two different directions
/ Dual Dozer
This rig can do compound grades. Now all I need is a dual plane laser. I have to fix the broken bank first.
/ Dual Dozer #11
Sounds like you are almost in business
/ Dual Dozer #13
A few more fabrication pictures.
The plate needed to be mounted high allowing the rear scraper door to hinge, but that required extra diagonal braces and removing the SS door when being used. Although not necessary, I had it sandblasted & powercoated at a local shop. Overall, seems like an easy option for the OEM to offer.
Maybe I should have posted this in welding/projects/fabrication, but this forum seemed better for construction applications.
/ Dual Dozer #14
That ad extra weight on that box blade for tractor use too. Most box blades are a little light. That's pretty neat indeed.
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
New - Front mount rototiller
New - Front mount...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
Landhonor Quick Attach Power Rake (A66408)
Landhonor Quick...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
