DT360 Filters
/ DT360 Filters #1
tj1989
Does anyone know the crossover filter numbers for the DT360? I need a new air filter, hydraulic filter, oil filter but do not know what Wix or other filters I can use in replace of the factory filters. Thanks for everyones' help.
/ DT360 Filters #2
Check out this thread and find your Montana equal on the PDF in the first post. http://www.tractorbynet.com/forums/montana/86217-magic-filter-xref-list.html
Is your DT360 the same as a Montana 3840?
If it is here are some donaldson part numbers that should work
Fuel P502134
Air P821575
Oil P502067
Hyd P55242
/ DT360 Filters #4
So if it is the 360DTC I presume it is the same engine as my 390HST.
Farmtrac / Landtrac PN: Q1400001
WIX PN: 51064
NAPA PN: FIL 1064
Using that you can go to any auto store and pick one up. I ended up buying a little bit higher quality one from Advance and getting a wrench to fit it. The original Farmtrac filter will have a PN on it, and if it is the same as above those #s should work. I think I crossed them off the Wix site.
/ DT360 Filters #5
Here are the filters from the parts manual on the 390 HST:
Hydraulic / Hydro: LG4399 / A1823315
Oil: LG2659 / MD134953
Air primary: LG3304 / A1190111
Air Safe: LG3305 / A1190112
Interestingly the oil filter MD134953 references a different filter than was on the tractor. The specs on WIX's site indicate a different bypass filter valve setting (that setting is lower on the MD134953 filter) and a slightly smaller housing, but same thread size. I am thinking of trying the different filter next time I change the oil.
/ DT360 Filters #6
Btw, I wnated to ask did you manage to cross reference the air filters to Fram or another manufacture? I wnated to replace the air filters here soon and can't get the ones in the parts manual to cross reference to anything. I did manage to find a fram filter part number for a Mitsubishi S4L engine which I think is the correct primary filter. That part number is CA9550SY. However, I haven't been able to find anything for the outer "safe" filter yet.
/ DT360 Filters #7
Hmm, actually I had a reference to a Montana tractor that had the same engine as the HST390 and I think I found the correct air filters. I crossed PNs:
DONALDSON P822858 to WIX PN 42985 for the inner filter
and
DONALDSON P821575 to WIX PN 46438 for the outer filter.
When I crossed that Fram filter I found, it also crosses to the Wix PN 42985, so I think those are the correct filters. I'll let you know when I get them sometime in the next week or so.
/ DT360 Filters #8
I don't remember all the part numbers but we were able to get all the filters from NAPA.
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
QLF Lick-tank (A66408)
2015 Jeep Renegade Latitude SUV (A64557)
2015 Jeep Renegade...
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
FECON CEM36EXC2-FS-XXV-0LPK11 DRUM MULCHER (A64277)
FECON...
100 Gallon Galvanized Water Tank (A65579)
100 Gallon...
