drywall/router tool
   / drywall/router tool
That's a pretty good testimonial, Duane.
I ordered the bit pack for doors and windows. I figured they must be designed for longer continuous run times and keep the bit cooler plus they have the smooth end to be used against a guide (the wood framing). I noticed that some of their bits must be designed to make their own start hole. 10 bits were as much as the tool! It's funny how electric/battery tools keep getting cheaper, but the working end doesn't.
I plan on doing a couple practice cuts first to see if the same bit will cut the FRP attached to the drywall or if I need to cut the drywall out first, glue the FRP in place and then use a different bit or method. I'm wondering if things will gum up once the adhesive heats up plus the FRP...
Does anyone know this, I'll try to get by without starting another thread:
I was going to rent a powder actuated fastening gun to attach the 2x4s to the block wall. They will be anchored the flat way, so I will be shooting through the 1-1/2" into the block. It's obviously pretty important that the nails countersink themselves pretty much for when I hang the drywall.
Is this expecting too much? Am I better off just going with Tapcons? Is seems like I remember the newer guns having adjustments to help vary the strength of the charge and my block walls are pretty uniform....I know which one I'd rather use /forums/images/graemlins/smile.gif
</font><font color="blue" class="small">( What better way to test the warranty then to work a tool hard right from the start )</font>
Sort of the old break it in like you're going to use it. Uh-oh, let's not start that discussion again... /forums/images/graemlins/grin.gif
   / drywall/router tool #23
Fred,
I used a Ramset to attach my framing to my basement floor. I used the 2 1/2" nails with the yellow loads, which, I believe, are the strongest. Everything's holding up real well, and yes, the nail should be a little recessed using the yellow shells.
I also used my Dremel for my drywall cutouts. They make an attachment for it to turn it into a mini RotoZip. Worked great!
   / drywall/router tool #24
Okay several questions to answer here.
Yes it is dusty but I have never had a Roto-Zip fail, except one and it had a faulty switch from the begining not dust related that was under warrenty. I called Roto-Zip and they mailed a new one to me that day.
If I have a sheet that overhangs a wall I would not use a utility knife, I would hang it and zip off the end. This keeps you from having to measure the wall, then measure the sheetrock, score it several times and breaking it. By just hanging it and cutting it you get an absolute perfect cut that is dead even with the end of the wall. In far less time than it took to type this.
Yes the bits are expensive but if cutting just sheetrock they last virtually forever. Just remember to keep the tool at a 90 degree angle to the cut and most important do not set the blade too deep into the collar.
</font><font color="blue" class="small">( and yes, the nail should be a little recessed using the yellow shells )</font>
Super. I was also thinking 2-1/2" nails with the yellow loads.
I'm kind of on a time scheduled for finishing as quickly as I can after I start this project and you all have helped tremendously in helping me plan ahead.
   / drywall/router tool #26
I've always been pleased with the tapcons - carry both a hammer drill and a drywall gun, and use the phillips flat head versions. Drill the hole with the hammer drill, clip it onto the tool belt, grab the drywall gun and tapcon and run it in. Better still with 2 people. First holds the 2x4 while the second drills, then the first screws in the tapcon while the second drills the next hole.
I find the Tapcons tend to be cheaper, as well as faster, but then I'd have to rent the Hilti
   / drywall/router tool #27
Just about the only thing those little routers are good for is drywall and laminate. The bits break too easily, and even a 1/4" spiral bit doesn't have the bite to agressively cut even 1/2 plywood.
The real use of those gizmos is for electric boxes, lights, etc, where you are plunge cutting. For windows, etc., you may as well use a knife to cut the drywall.
I don't know what FRP is.
As for the wood frame, you have to be carefull: if the tool slips or the bit is set wrong you will easily cut into the frame.
   / drywall/router tool #28
hi all:
My brother is a full time drywall hanger/finisher. he has his own buisness and I did it with him for a year or two...
]yes you can cut out just about everythign with them. BUT they do creat a good bit of dust. with if bit is turned into dust for every inch of cut you make one inch of dust is created one bith wide by drywall width high. best use is for doing boxes light switch covers can lights and windows. perimiter nail the drywall on after marking all the box locations using the drywall hammer hatchet end to punch a small hole into it at the box location. nail lightly (nit TIGHT) and rotozip out the box/window and then finish nailing it down tight. zip CAN be used for doors but we find that a good drywall HAND SAW (short looking hand saw about 24" long by 6"wide at handle end and 4" at tip ) with an agressive kerf. cut the vertical part then use utility knife to scarf the paper along the door jam top edge. snap it back (out away from frame) and use the saw tip to scarf the top face edge of the drywall by reaching up and over the now snapped back drop. run bottom door jam edges out and over door frame and then cut back side of drywall with utility knife and snap as normal. cut front face edge with knife too after the snap.
when cutting with the roto zip always go in a (I think it was)counter clockwise rotation so the bit is pulling into the cutout. (rotation forces keep the blade tight to the cutout object as the tip rides on the object.) it has been 10 years since then! lol. anyhow they last a good long time and need to be torn down and blown out to keep them going. the switches are the weak part for sure... (now also the brushes are getting hard to get as the MFG don't want to sell em to ya they want to force ya to buy new one insted.) /forums/images/graemlins/shocked.gif
MarkM
I may end up going the tapcon route, Eddy.
I guestimated about 600 fasteners. The cheaper way to buy them from the Hilti rep (I used to deal with him and he will lend me the better gun with the bells and whistles) is to buy 1000 charges and nails for $280. The hardware store by me rents the gun for $14/day and has the charges and nails for $17/100.... or so they told me over the phone. That's a pretty big difference and I might stop there tomorrow to make sure. The problem with their gun though, is it's the plain Jane model. All you have is the charge itself and their aren't any adjustments for adjusting the strength of the charge if needed.
On the other hand, I can buy 600 tapcons for $72 plus pick up the tool (I highly recommend the tool that allows you to switch from drill bit to screw bit without changing drill motors or messing with the chucks) for $40.
Obviously Hilti is out of the picture and I need to doublecheck my phone quote from the local hardware store on their gun.
I'm hoping I see my roto-zip by the end of the week. I'm anxious to try it out /forums/images/graemlins/laugh.gif
   / drywall/router tool #30
I'm restoring an 1873 home and living in it all the while. I'm real familiar with dust and where it all ends up. If you don't want the dust cleanup, a drywall saw would be your best bet for larger openings. The coarse teeth don't make much dust. Nail it up, cut opening and fit FRP
Booster Cables (A59230)
Booster Cables...
40' CONTAINER (A52706)
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
1999 Toro...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2015 CATERPILLAR 815F2 SOIL COMPACTOR (A60429)
2015 CATERPILLAR...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
