drywall fine thread screws to install drywall in wood studs instead of metal studs
   / drywall fine thread screws to install drywall in wood studs instead of metal studs #11
Don't forget the glue!
   / drywall fine thread screws to install drywall in wood studs instead of metal studs #12
Put glue on studs and use screws to hold rock till glue sets.
I went through a Uni-built home in Vandalia, Ohio and they used a spray foam type sealant also on the studs to glue and seal.
   / drywall fine thread screws to install drywall in wood studs instead of metal studs #14
Surprised nobody mentioned why threads are different for wood versus metal. Framing lumber is fast growth softwood. Course threads hold better because they get a deeper grip than fine threads in soft material. They may work but that is not what they were designed for and there is good reason to believe that they may not hold as well given the small movements wood framed structures make. It's your house. You only get one chance to assemble it correctly. Free fasteners could be a costly mistake.
   / drywall fine thread screws to install drywall in wood studs instead of metal studs #15
Will they work, yes. That is not the real question. The real question is will they pull out of the wood when the unavoidable movement starts. Unfortunately the same answer applies, yes.
   / drywall fine thread screws to install drywall in wood studs instead of metal studs #16
Yes, but if you are concerned due to unusually light studs, use an extra screw per stud (use 6 screws per 4-foot attachment to a stud instead of 5 screws). Additional screws are often used in drywall for applications where the wall is needed for some shear support.
   / drywall fine thread screws to install drywall in wood studs instead of metal studs #17
I was given 15 pounds of fine thread drywall screws intended for drywall attachment to metal studs. Have drywall I want to attach to wood studs. Will they work for same?
Absolutely will work until they pop out later. Use the proper screws when installing drywall no matter what screws someone gave you free.
   / drywall fine thread screws to install drywall in wood studs instead of metal studs #18
They will not bite into the wood as good as coarse thread, but you can help yourself by using construction adhesive. Especially on the ceiling.
   / drywall fine thread screws to install drywall in wood studs instead of metal studs #19
One good ground shaking event may show you why the metal stud screws are not designed to be used with wood studs.
If you live in an earthquake zone an inspector there would write a correction notice if they caught it.
   / drywall fine thread screws to install drywall in wood studs instead of metal studs #20
They will work fine and will be easier to drive in old wood than course thread. I have been dong sheetrock for a long time and all I use is fine thread. Aside from being easier to drive into old wood 1 screw works for both metal and wood
MILWAUKEE & DEWALT SAWZALL (A58374)
MILWAUKEE & DEWALT...
Adams 6 Ton Fertilizer Spreader (A56435)
Adams 6 Ton...
Pneumatic Grease Can w/Chevron Delo Starplex EP 2 (PARTIALLY USED - AIR HOSE REEL NOT INCLUDED) (A59076)
Pneumatic Grease...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
8" Wilton Vise (VISE ONLY) (A59076)
8" Wilton Vise...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
