Dry, Lubed, or sealed.
   / Dry, Lubed, or sealed. #11
   / Dry, Lubed, or sealed. #12
Your 2 cents are worth a lot. A philosophy degree has likely enhanced your ability to discern what is important and what is not. You might like this book, which is a bit philosophical: "Shopcraft as Soulcraft: An Inquiry Into the Value of Work," by Matthew B. Crawford 2009. It was a New York Times bestseller.
   / Dry, Lubed, or sealed. #13
:eek:I'm so tired from my own "Shopcraft/Soulcraft" that I hardly ever read anymore for enjoyment. I rise in the dark...work until it's too hot...nap...eat...then work until dark. A little TBN is my main enjoyment and an ocassional TV (no cable). Being a widower, living alone the "Shopcraft/Soulcraft" gives me time for a lot of good memories however.:) Thanks for the thought Mr Mcconoughey.
   / Dry, Lubed, or sealed. #14
When I assemble an engine, I use thread sealent, on the threads and under the head of the bolt or nut. I use lock tight, on the caps, and the mains, and the camshaft retainer bolts [nuts], oil pump. Every thing else is oil. Yes after maney years, one can tell just how tight to tighten a bolt, even with a impact gun. Untill I bought a new gun, witch is more powerfull. Now I have to be very carfull when using the new inpact gun.
David-Davies
   / Dry, Lubed, or sealed. #15
Another vote here for never sieze. Especially good on lug nuts - no more screeching/galling noise and loose metal particles when changing wheels.
Shopcraft as Soulcraft was a welcome read. Somebody finally making sense. Right up there with Zen & the Art of Motor Cycle Maintenance ... and I thought they didn't write them like that anymore.
-Jim
   / Dry, Lubed, or sealed. #16
Anti-seize, use it pretty much on all threaded machinery fasteners unless there is some exceptional reason not to.
Anti-seize is especially useful on shiny new vehicle wheels, particularly aluminum wheels to cast iron hubs (hub centrics) before corrosion sets in and a hammer is needed to separate the components.
International 490 24ft Disc (A52128)
International 490...
1992 TIFF Motorhome (A50324)
1992 TIFF...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
(4) 3 PLUG VALVES (A52472)
(4) 3 PLUG VALVES...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
